Author Topic: 123 ignition - which coil please? Seems lots of options.  (Read 5105 times)
Paul99
  • 230 SL White. 1966.
I notice 123 have on their website to use the Bosch BLUE coil, which is discontinued.  Others same the flamethrower coil, or the Bosch Black or Red coil!  Some say 1.5ohm, some say 3 ohm Some say keep the ballast resister some say not.
What is the general consensus?    I now have the Bosch Black 3.4 ohm coil 9 224 771 008  with no ballast resister fitted and all seems ok .
BobH
Re: 123 ignition - which coil please? Seems lots of options.
« Reply #1 on: July 11, 2023, 19:33:11 »
Hello Paul, as usual many differences of opinion, and many seem to work satisfactorily, but reply #15 seems to be the definitive advice from the manufacturer for our cars
https://www.sl113.org/forums/index.php?topic=23428.msg167802#msg167802
From the manufacturers website, slightly contradicts their advice in the above post
"For 6 cylinder engines we advise to change your coil to a high performance coil because of the short load time in the higher rpm range. Make sure you use coils with a primary resistance of at least 1.0 Ohm. ( 1,0 Ohm or more ) For standard street engines we advise a “Bosch Blue” or “Beru ZS106” coil. For high rpm engines a “Bosch red (0 221 119 030)” or “Beru ZS109” is much better."
« Last Edit: July 11, 2023, 19:38:26 by BobH »
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
Paul & Dolly
  • i Car
« Reply #2 on: July 11, 2023, 20:26:01 »
I have a Bosch Red coil on mine, works fine.
Paul
Mitsubishi i Car
Toyota RAV 4  Hybrid AWD
alpina
  • Spain, Asturias, Villaviciosa
« Reply #3 on: July 12, 2023, 07:43:43 »
Bosch Red coil with bypassed / No ballast resister as recommended by 123ignition.nl
« Reply #4 on: July 12, 2023, 12:41:19 »
BERU ZS115 coil and no ballast resistor on my 123 ignition. Runs very well.
Paul99
« Reply #5 on: July 12, 2023, 13:09:45 »
Great thanks chaps.
I have the Bosch black coil which seems the same specs as the red coil so will try it and see what happens.   It's slightly anoining that 123 seem to change their mind a bit.  But looks like the 3ohm and high capacity coils are the answer.
« Reply #6 on: July 12, 2023, 19:19:45 »
Great thanks chaps.
I have the Bosch black coil which seems the same specs as the red coil so will try it and see what happens.   It's slightly annoying that 123 seem to change their mind a bit.  But looks like the 3ohm and high capacity coils are the answer.
Black coil is 13KV and red coil is 26KV.
123ignitionusa
  • USA, OH, Columbia Station
« Reply #7 on: February 13, 2024, 18:47:23 »
https://www.123ignition.com/support/ which is the mfg website has always said use a coil of one ohm or higher. There are other retailers that may or may not stick to the mfg recommendations. This depends on your engine:
On a Citroen 2cv: DON’T use other coils than the standard. Best advise : buy a new black 2CV-coil, and new (silicone) ignition leads. The Brown VISA coil will ruin your ignition because these coils have a very low primary resistance.
For 2 cylinder DAF or FIAT engines you could use the stock coil or an other standard coil ( about 3 Ohm primary resistance )
For 4 cylinder engines you could use the original coil or other coils with a primary resistance of at least 1.0 Ohm. For standard street engines we advise a “Bosch Blue” or “Beru ZS106” coil. For high rpm engines a “Bosch red (0 221 119 030)” or “Beru ZS109” is much better.
For 8 cylinder engines we advise to chance yor coil to a high performance coil because of the very short load time in the higher rpm range. Make sure you use coils with a primary resistance of at least 0.6 Ohm. ( 0,6 Ohm or more ) For low rpm engines a “Bosch red (0 221 119 030)” or “Beru ZS109” will be a good choice, for higher rpm engines we advise a Pertronix Flame Thrower II 0.6 Ohm.
Note: We hear a lot of complains from our customers about the fake “Lucas Sport” or “Lucas gold” coils, better don’t use these coils.
« Last Edit: February 13, 2024, 18:55:36 by 123ignitionusa »
