Author Topic: 1970 280SL fuel capacity dilemma  (Read 3873 times)
mmizesko
  • USA, OH, New Albany
« on: July 09, 2023, 23:40:48 »
OK guys,
I never let my fuel get down below R. but close to it, before filling.  when i do, it only takes about 14 gallons US.  then the gauge goes up to above F, and if i keep at it, the expansion tank and the whole car stinks like gas.  I just read again that the tank capacity is 82 L or 21.5 us Gallons.
So is there really 7 gallons left in the tank below the R on the gauge?  Someone has got to know.  Help? Please?
Mike
1970 280SL 291H Dark Olive
Kevkeller
  • USA, HI, Honolulu
Re: 1970 280SL fuel capacity dilemma
« Reply #1 on: July 10, 2023, 01:42:18 »
Very doubtful. You can always open up the plug and drain it or the access plate on the top to look inside the tank.
1970 280 SL
mmizesko
« Reply #2 on: July 10, 2023, 02:10:53 »
good advice.  Maybe I'll just drive the 5 miles to Joe Alexander's place.
Mike
Lori
  • USA, NC, Charlotte
  • 1968 280SL (US)
« Reply #3 on: July 10, 2023, 02:19:21 »
Per my owners manual the light means 22-25 miles left which I believe would be about 1 gallon.
Lori
1968 280SL (US)
yves
  • France, Poitou-Charentes
  • Happy owner of a 69/ 280 sl , 63 Etype ,55 XK 140
« Reply #4 on: July 10, 2023, 13:41:52 »
I have recently emptied the tank to know excatly when the fuel reserve light light up because i have never seen it switched on as i refuel before the needle is too low. Also my gauge stay high after filling but goes down quickly after 2/3 or 1/2 .
What I saw is that the reserve light is on when  i have less than 5 liters .
Under is my scale when i have fulfilled my tank :
Happy owner of a 69 blue 280SL ,  63 FHC  osb E-type , 55 FHC XK 140 to be restored...
« Reply #5 on: July 10, 2023, 15:39:03 »
Yves, I frequently fill mine to 65 liter of fuel (17.2 gallon) or on occasion 70 liters (18.5 gallon). Don't you ever get that high?
Is the cork seal at the fuel sender unit intact or is it seeping with petrol?
Do you have a big dent in your tank?
yves
« Reply #6 on: July 10, 2023, 16:03:56 »
Peter  , the 40 lit level is not full , it is what I had in the tank when I have tested the reserve.
lreppond
  • USA, CA, San Leandro
« Reply #7 on: July 10, 2023, 17:02:59 »
I have noticed that my fuel gauge needle can be somewhat erratic (jumpy) depending on the road surface.  On a rough road, the needle can make huge swings.  On an incline or downhill, the gauge will always read differently.  I’ve pretty much just written off the fuel gauge as a poorly functioning system.  Im wondering if others have experienced the same.  As to the accuracy of the readings, I have lost all faith in mine.  I routinely do a fill up when the gauge reads 1/2 even though I have no idea how much gas is actually in the tank.
~Len
1971 280 SL
576G red/251 Beige
4 speed manual
BobH
« Reply #8 on: July 10, 2023, 17:27:45 »
Hello, my needle is pretty stable, but the slightest incline can move the needle significantly.  i guess the condition/resistance of the wiring and the sender unit can all play a part.  The only time i'm confident that the gauge is accurate is after i've filled the tank up, after that it's like Russian roulette!  I just get into the habit of filling it regularly and ignore the gauge, and the clock for that matter!
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
zak
« Reply #9 on: July 10, 2023, 19:22:38 »
My fuel gauge acts erratically when I first start and drive the car. It reads lower than it should.
But in 5 mins it seems to correct itself. It bounces around a good bit too. I also pretty much ignore it and fill up at a quarter tank.
...just one of those endearing aspects of owning a 60 year old classic car I guess.
Mike M, hope you find the source of the gas odors.
jz
1967 250 SL
1983 280 SL
2015 ML 250 Bluetec
2007 ML CDI
2004 E 320 Wagon
1999 E300 Turbodiesel
