Author Topic: well that was interesting drivers door mirror just fell off  (Read 2576 times)
merrill
so,  i was out running some errands in the 230sl,
got on the freeway and out of my peripheral vision i saw my drivers mirror rotate and then just fell off.
what is left is just the arm
luckily i have some backups from junkyard picking, now to decide if i should just replace the whole assy or just the mirror.
just one of those things i guess
« Last Edit: June 02, 2023, 12:30:55 by merrill »
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
badali
  • USA, Pa, Butler
  • 1966 230SL
Re: well that was interesting drivers door mirror just fell off
« Reply #1 on: June 01, 2023, 16:06:30 »
If the condition of the mirror post is in similar condition I would just replace the mirror head.  Taking apart the door panel could open a can of worms.
Brad
1961 220 Sb
1966 230 SL (Sold)
2019 E 450 4 Matic
2022 GLC 300 4 Matic
2025 E53 AMG Sedan
merrill
« Reply #2 on: June 01, 2023, 18:22:02 »
Brad
hi
yes,
looking for the spare mirror assy i had.
so far i can only find arms, the chrome head and mirror.
I might just end up buying a new head from Buds benz if i can get the spring also
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
merrill
« Reply #3 on: June 04, 2023, 15:07:24 »
so
I couldn't find the backup mirror assy,  its around here somewhere,  of course i "organized" everything so its somewhere.
anyway  Buds has a re-pop kit which i ordered.
comes with all the parts in the picture.
i checked the technical forum for assembly instructions but could not find any
I am guessing the process is as follows
1. screw, small spring, chrome housing and nut get secured first
2. large spring, mirror get held in place while the plastic trim is put in place.
any other guidance would be appreciates
thank you matt
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
merrill
« Reply #4 on: June 06, 2023, 20:16:59 »
kit received from Buds
the installation is as follows
screw thru washer, into the arm
then chrome housing and nut.  (the nut is indexed to lock into the arm
once secured then large spring, mirror and then plastic
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
