Author Topic: "HORN HELP"  (Read 2518 times)
John Betsch - "SADIE"
  • USA, NY, SOUTHOLD
"HORN HELP"
« on: May 12, 2023, 22:57:06 »
When I acquired my 230SL (over thirty years ago) It had only once horn.  I am finally correcting that situation.  Unfortunately I have no idea how the second horn should be wired in.  I only see one wire going to the existing horn (passenger side)
Can anyone help with info on how the two horns are wired? Parallel, in Series?  Connected to what etc?  I couldn't find much in the Tech Manual
Any advice to a novice is appreciated
JB
DavidAPease
  • USA, CA, Chico
  • Club Treasurer
Re: "HORN HELP"
« Reply #1 on: May 12, 2023, 23:14:34 »
John,
This very recent thread has all the information you should need, and perhaps more!
   https://www.sl113.org/forums/index.php?topic=36602.0
Much thanks to our electrical guru, Eng. L. Peterssen, for sharing his expertise!
             -David
-David Pease
  • USA, NY, SOUTHOLD
Re: "HORN HELP"
« Reply #2 on: May 14, 2023, 20:11:10 »
I can see where the wiring for a passenger side horn is routed (appears to be routed through the air filter housing.)
I cannot find any wiring on the drivers side.  I assume that sometime in my pagoda's lifetime it was cut for some reason.  I am guessing that wire from the horn would be routed up into the ?engine compartment, and travel along the driver side firewall?  Anyone have any ideas or pictures?
« Last Edit: May 15, 2023, 00:58:30 by John Betsch - "SADIE" »
dirkbalter
  • USA, CA, Corona
Re: "HORN HELP"
« Reply #3 on: May 14, 2023, 20:43:24 »
The passenger side wiring should come from the driver side connection. The wiring harness is routed along the left side to the left horn.  From there,  two wires (same colors) take off along the front to the right horn.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
