Author Topic: Where are these parts from ?  (Read 2934 times)
yves
  • France, Poitou-Charentes
  • Happy owner of a 69/ 280 sl , 63 Etype ,55 XK 140
« on: May 08, 2023, 17:57:45 »
Well.... i am reassembling all the dashboard  instruments after refurbishing the heater core  ::) and found on my bench some parts in separate bags...and  some of them i don't know where they go !
N° 1 in the photo seems to be a plug for the radio or antenna but the radio is all connected ! it is stamped BERU 1K
N° 2 and 3 are small finger nuts but from what device?  not the clock because the nuts are already fitted ,
N°4  is a 10 mm nut , 3 mm thick found on the floor while refitting the dash....!
your help will be appreciated....!
Thank's in advance
Happy owner of a 69 blue 280SL ,  63 FHC  osb E-type , 55 FHC XK 140 to be restored...
Davek1
  • United Kingdom, England, Wells
Re: Where are these parts from ?
« Reply #1 on: May 08, 2023, 18:58:02 »
Hi there, I think No3 is a curb nut holding the instruments in the dash, not sure of the others though.
Figoulu
  • France, Languedoc-Roussillon, Villeneuve les Avignon
« Reply #2 on: May 08, 2023, 18:59:41 »
And of course those parts were removed from you I guess…
I mean it wasn’t left somewhere under the dash as sometimes you could find abandoned or disconnected stuffs
For having done the same job I couldn’t find a clue where go your parts…
Good luck 👍
1965 230 SL
1991 Porsche 911/964 carrera 2
My youtube channel #lfgdf
BobH
« Reply #3 on: May 08, 2023, 19:03:09 »
Hello Yves, number 1 is a spark plug lead connector at the distributor
2&3 look like the knurled nuts that hold the brackets for the tach, speedo and instrument cluster, i don't know if these are all the same size, you may have to have a fiddle with them
No idea about number 4
Have a look on here
https://www.sl113.org/wiki/Electrical/DashboardInstruments?action=download&upname=Removal230SLInstruments.pdf
Just a thought, aren't the chrome dash pieces around the vent levers held on with 10mm nuts?
« Last Edit: May 08, 2023, 19:23:11 by BobH »
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
Figoulu
« Reply #4 on: May 08, 2023, 19:32:32 »
Have a look on here
Exactly… now it comes back to my mind for 2 and 3…
1965 230 SL
