Author Topic: Fuel Pump Mounting: Is this right?  (Read 3210 times)
Raymond
  • USA, FL, Jacksonville
    • GemstoneMediaInc.com
« on: April 20, 2023, 13:46:15 »
I haven't been able to find a photo convincing me I'm installing the pump correctly.  Some previous owner had bent the mounting bracket and installed the short fuel pump directly to it without the circular "horseshoe" adapter.  It never had a protective shroud around it.  Last week, the vibration dampers failed and the fuel pump dropped off, breaking the ground wire and dangling from the hot lead and fuel hoses.  I ordered the adapter plate and managed to bend the mounting bracket back into shape so the adapter fit. I think I have that right, but the fuel pump now sits more than an inch lower.  So, I've attached photos of how I have the pump positioned before I tighten everything and re-route the hoses.  Is this right?
Figoulu
  • France, Languedoc-Roussillon, Villeneuve les Avignon
Re: Fuel Pump Mounting: Is this right?
« Reply #1 on: April 20, 2023, 13:53:31 »
If you're patient you'll find in my video the answer at the right sequence from 7'21
https://youtu.be/W-mW7F-HJus
« Last Edit: April 20, 2023, 14:48:52 by Figoulu »
1965 230 SL
1991 Porsche 911/964 carrera 2
My youtube channel #lfgdf
afibbe
  • USA, OH, Cincinnati
  • 513-374-5600
« Reply #2 on: April 20, 2023, 15:25:43 »
Great video. I wish I understood French but a picture paints 1000 words. This video will help me when I reinstall my fuel tank and pump in a few weeks.
On a side note:  You can purchase rubber covers specifically designed for the fuel pump wire terminals.
Alex Fibbe
1966 230SL
USA, Cincinnati, OH
GM
  • USA, CO, Boulder
« Reply #3 on: April 20, 2023, 15:42:50 »
Just activate the closed captioning feature in the video
Gary
1971 280SL - Sold
DB180 Silver Gray Metallic
Black MB Tex
Raymond
« Reply #4 on: April 20, 2023, 21:10:29 »
Closed captions are also in French.  However, that is what I needed to see.  Thanks!
GM
  • USA, CO, Boulder
« Reply #5 on: April 20, 2023, 23:12:46 »
Go to settings - auto-translate, and choose language
Gary
1971 280SL - Sold
Black MB Tex
Figoulu
« Reply #6 on: April 21, 2023, 15:41:04 »
For any Youtube video you can subtitle it by pressing the right icone on the edge of the video screen
I bought the rubber covers afterwards and fixed them up
1965 230 SL
afibbe
  • 513-374-5600
« Reply #7 on: April 23, 2023, 03:01:08 »
Thank you. I can watch these utub and understand what is said.  You did a very good job creating these videos.
Alex Fibbe
1966 230SL
USA, Cincinnati, OH
