Author Topic: 230SL spare tire mount year change  (Read 4526 times)
SoupedUp
« on: April 13, 2023, 15:36:16 »
I have a 1966 230SL.  The spare tire is in the upright mounted position on left side of trunk sitting in the spare tire carrier hole. When did the 230SL get rid of the spare tire carrier cubby hole just laid the spare tire flat with a hold down?
cfm65@me.com
  • Cape Town, South Africa
Re: 230SL spare tire mount year change
« Reply #1 on: April 13, 2023, 16:45:39 »
SoupedUp,
I believe you have it the wrong way round. If I remember correctly, the early Pagodas had the spare, sort of upright and the later models had a bigger fuel tank and therefore a spare horizontal on about a 6 inch post.
My first one, a 65 230SL had the upright spare and the next two, a 71 280SL and 67 250SL both had a bigger tank(80 litres IIRC) and a flat mounted spare on a post, raising the wheel a few inches off the boot floor and moved over to the right.
Chris
« Last Edit: April 13, 2023, 16:53:43 by cfm65@me.com »
28 Ford Model A Pickup
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
2015 VW T5 California Pop Top
« Reply #2 on: April 13, 2023, 18:08:25 »
The list of changes published in Pagoda Notes (Vol 10 No.1) has the following for the spare tire change
24 Sept 1964 - prototype installed in 230 SL with VIN ending 6069
23 Oct 1964 - change made to horizontal spare at 230 SL VIN ending 7205 with the following exceptions VINs ending 7216, 7232, 7253, 7277
« Last Edit: April 14, 2023, 16:50:43 by Jonny B »
« Reply #3 on: April 14, 2023, 13:00:07 »
SoupedUp,
What you have is a conflict that you might want to resolve for your own peace of mind.  A 1966 should have the flat spare with the larger fuel tank.
- What is your VIN?
- Maybe your registration/title is incorrect in stating 1966 for some reason.  (More likely)
- Maybe your newer car has been changed to the older style trunk & spare tire  (Less likely)
SoupedUp
« Reply #4 on: April 14, 2023, 15:45:49 »
VIN
11304210006130
« Reply #5 on: April 14, 2023, 21:21:05 »
My reading is that it was an August 1964 production. So its definitely not a 1966 vehicle but it is right at the changeover of the tyre holding method so a vertical spare floor is probably correct and from the final parts bin in production line.
« Reply #6 on: April 14, 2023, 21:32:53 »
SoupedUp,
- What is your VIN?
All 230SL's had the 65 liter fuel tank. I have a '66 and changed it to the 82 liter tank so I'm sure of this.
Whatever is in this car is likely correct.
MikeSimon
  • USA, OH, North Royalton
« Reply #7 on: April 14, 2023, 22:29:30 »
Is it allowed to disagree? All these have the spare lying flat in the trunk:
https://bringatrailer.com/listing/1964-mercedes-benz-230sl-27/
https://bringatrailer.com/listing/1966-mercedes-benz-230sl-49/
https://bringatrailer.com/listing/1966-mercedes-benz-230sl-48/
https://bringatrailer.com/listing/1966-mercedes-benz-230sl-46/
..and there are more.
My parts list shows the 65L fuel tank p/n 113 470 0601 only through 230SL serial-no 000203
« Last Edit: April 15, 2023, 01:00:53 by MikeSimon »
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
« Reply #8 on: April 15, 2023, 03:32:53 »
I have a factory dealer's parts book and yes, there is a foot note on VIN 203. However that footnote only indicates a design change and not the size of the fuel tank which remained the same throughout  230SL production.
So yes, you can disagree if you like, but my late '66 says otherwise.  :)
WRe
« Reply #9 on: April 15, 2023, 06:03:18 »
Hi, - my 2 cents -
according to Xentry parts information for 230 SL: A 113 470 02 01 to VIN 202; A 113 470 03 01 replaced by A 113 470 06 01 from VIN 203.
ALL 65l , although there would have been space for the large one (from VIN 7204).
The spare wheel trough was omitted from end of 1964, a possible tank enlargement could have followed from January 1965.
Then uniform for 250 and 280 SL: A 113 470 07 01 (82l).
...WRe
MikeSimon
« Reply #10 on: April 15, 2023, 12:10:34 »
I read this wrong. The change was from serial number 000203 FORWARD not up to. It probably referred to the part-number only, not the size of the tank.
In any case, the OP needed to know when the spare tire mount was changed from upright to horizontal not the fuel tank size, and I think that has been determined
« Last Edit: April 17, 2023, 12:05:23 by MikeSimon »
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
German specs
3rd owner
« Reply #11 on: April 15, 2023, 18:36:30 »
Looks like we are all talking about the same thing.
« Reply #12 on: April 17, 2023, 04:37:11 »
VIN
11304210006130
SoupedUp,
So, I hope you are satisfied that the VIN shows a 1964 build.  If you want to work on changing your title or registration, that is up to you.  As always, order parts based on your VIN to eliminate errors.
SoupedUp
« Reply #13 on: April 17, 2023, 12:52:55 »
According to history the car has been titled as a 66 since new. 2 owner car
« Reply #14 on: April 17, 2023, 14:19:31 »
It must have sat in inventory for a long time.  Perhaps it was used by Mercedes-Benz for some corporate or dealership purpose and never titled until sold to the public?
john.mancini
  • USA, FL, Nokomis
« Reply #15 on: April 18, 2023, 20:38:18 »
Back in the day, the year of imported cars was determined by the date it was sold from the dealer, not the production sequenced VIN. I have an early 65 that was sold in 66, thus the title says 66. That was changed, (please correct me if I am wrong), for model year 1969 in the USA. That's when cars were titled according to their production model year, not the year they first sold.
65 230SL 519 Red 4-sp
98 911 cab
56 Ford F100
08 Porsche RS60 Spyder
23 Z4M40i
« Reply #16 on: April 18, 2023, 20:42:43 »
SoupedUp,
That's an interesting looking spare tire!  I don't see any markings on it.  Can you tell us what it is?  Might it be factory original spare??
SoupedUp
« Reply #17 on: April 18, 2023, 21:50:45 »
Firestone Phoenix
