Author Topic: sloppy shifting  (Read 2688 times)
boterinse9
  • USA, IL, marengo
sloppy shifting
« on: December 13, 2022, 23:27:41 »
My shift lever is loose seems like shims are missing  onbottom of stick but I dont see them on any prints any  Ideas all other bushings seem OK . appreciate any info
1970 280 SL Silver Automatic
1976 300D White
2012 C300 4matic
2004 chevy Silverado
Re: sloppy shifting
« Reply #1 on: December 14, 2022, 14:45:06 »
I'm not aware of any "shims" in this assembly.  I would bet that it is the bushings.  Have you done a search to find other threads about shifter bushings?  You can read other peoples' description of the worn shifter bushings and see if it matches your issue.
TJMart
  • USA, NC, Matthews
Re: sloppy shifting
« Reply #2 on: December 14, 2022, 16:32:21 »
Here is a link to a schematic that shows the parts for the automatic shifter. You can use this while researching our forum.https://www.sls-hh-shop.de/main/en/mercedes-230-280sl-w113-/27-automatic-gearbox/27-b-automatic-linkage-and-connecting-parts
Tony
1970 280SL, 4 Speed
boterinse9
  • USA, IL, marengo
Re: sloppy shifting
« Reply #3 on: December 14, 2022, 19:09:19 »
Thank you Tony ,that's exactly what I was looking for couldn't find it anywhere even the manual didnt show it  my whole bottom of the shifter was full of with grease and after cleaning it out just didnt look right  metal to metal didnt look MB ish I did buy a bushing kit or two but they didnt include those so now Ineed to order them  may be a bit tricky but well see Im not a comp person Idid bookmark the site and well go from there  and get the shifter problem out of the way and move on to the next which is drive shaft bearing and flexjoint then new seat covers Car got a new top last yr looks great  Again thans for the post, ill keep ya posted..Regards Boterinse.       Bernie ...
1976 300D White
2012 C300 4matic
Re: sloppy shifting
« Reply #4 on: December 14, 2022, 19:56:00 »
Is there a specific type of grease that should be packed around the shifter lever bushing?  I don't know what the bushing is made of, didn't know if simple axle grease is OK, or if lithium grease is required, or something graphite based??
