Author Topic: another confusing wiring issue starter / alternator  (Read 3454 times)
Figoulu
  • France, Languedoc-Roussillon, Villeneuve les Avignon
« on: December 12, 2022, 18:17:27 »
Hi gents
As I progress in the refurbishment of my car I felt puzzled with the wiring...
Some picture to illustrate the mess...
1965 230 SL
1991 Porsche 911/964 carrera 2
My youtube channel #lfgdf
Figoulu
Re: another confusing wiring issue starter / alternator
« Reply #1 on: December 12, 2022, 18:23:17 »
I took a lot of picture BEFORE I removed everything, but of course there's always a missing one that shows what you need to know...
And this is where I stand…
I guess some wires goes to the horns? But I cannot figure out the other ones…
I cannot make sure where to plug and connect the wires in yellow and with « ? »
Could you help me ?
« Last Edit: December 12, 2022, 18:31:50 by Figoulu »
1965 230 SL
BartSt
« Reply #2 on: December 12, 2022, 18:55:00 »
You should talk to Leo Petterson ...
Figoulu
« Reply #3 on: December 12, 2022, 19:10:19 »
Telling you the truth, i hope he comes by 😅😅
Found this… https://www.sl113.org/forums/index.php?topic=33692.msg246344#msg246344
« Last Edit: December 12, 2022, 20:28:21 by Figoulu »
1965 230 SL
lpeterssen
  • USA, FL, Miami
« Reply #4 on: December 12, 2022, 21:35:25 »
Dear friend
Write me free of charge to l.peterssen@me.com
And I will guide you on the process of reconnecting everything back in place
Nevertheless, from the pictures posted your harness is not in good shape. It needs someone like me to rebuilt it.
If you want to connect as is , which is not recommended write me to guide you step by step no charge
Best regards
L.peterssen
Figoulu
« Reply #5 on: December 13, 2022, 05:10:41 »
Hi
Thanks a lot for your proposal  :) I’ll contact you directly 👍👍
May I reassure you… the pictures are before I partially renew the wiring, and they are from the origin, BEFORE I intend to renew it
I almost collapsed when I discovered the battery / starter cable routed without the corresponding brackets and very close to the engine block (less than 2cm…) and the cable was partially without insulation… (see last pic below...)
I enclosed some pics about some yummy discoveries I made… including related to the fuel hoses…
Everything detailed in this video including timing chain desynchronized … : https://youtu.be/AwLPJmehM58
« Last Edit: December 13, 2022, 06:30:54 by Figoulu »
1965 230 SL
lpeterssen
  • USA, FL, Miami
« Reply #6 on: December 13, 2022, 22:24:08 »
Thanks Bart for the endorsement…..
I am in contact with Francois by mail now.  Solving the issue
I am available for all of you, you know I really like the wiring harnesses and understand them in detail.
Best regards
Leo Peterssen
Figoulu
« Reply #7 on: December 14, 2022, 09:19:58 »
Best regards
Leo Peterssen
Leo sent me a lot of informations by mail and whatsapp. May I publicly thank him for his enthousiastic involvment
I believe my issues are solved...
We stay in touch anyway for further discussion and I thank you all for your inputs and interests
« Last Edit: December 14, 2022, 21:11:29 by Figoulu »
1965 230 SL
