Author Topic: Undercoating  (Read 19710 times)
jsaylor
Undercoating
« on: June 11, 2005, 03:29:28 »
Having just had new floors and rocker panels instaled I'd love some input on the best undercoating  solutions for my ;65 239SL.  Any input would be appreciated,
Jim Saylor
Kauai, Hawaii
'65 230SL
Re: Undercoating
« Reply #1 on: June 11, 2005, 04:55:16 »
Hello Jim,
Be sure to clean the welds and bare metal with a wire brush or by sanding. Use a good rust inhibative primer on any bare metal. The Eastwood Company carries many restoration products. Also Rustoleum "rusty metal primer" is a  good product (available locally) and will brush on easily. Use a finish top paint over primer then  undercoat the areas. The factory used an "body schultz" (speeling?) which was a water based, thick, rubberized undercoat. A special "body schultz gun" is used to get the exact original texture. This product will accept a finish paint topcoat. The special gun is fairly inexpensive.  I have used the Seikens  "body schuttz" which I have been told was an original manufacturer for Mercedes. It worked very well and when using the gun the texture was perfect.
I have also used the 3M rubberized undercoat in the past. It has it's own applicator built in the aeriosol cans. The texture is not quite correct but it is a good product.
rjgricius1
  • USA, FL, longboat key
Re: Undercoating
« Reply #2 on: January 12, 2011, 01:19:05 »
JOE,
dO YOU KNOW A SUPPLIER FOR THE "BODY SCHULTZ"?
RON GRICIUS
230 sl 1967 automatic
wht/blue  in the middle of comple restoration
Re: Undercoating
« Reply #3 on: January 12, 2011, 04:55:46 »
Hi Ron, I have seen a version of Body Schutz (from schutzen -- to protect) available at most automotive paint stores. 3M I think. There was just a thread discussing Wurth undercoating which may have been the true original material. The 3M looks to be close enough.
zoegrlh
  • USA, VA, Williamsburg
  • Beauty from top BCW
Re: Undercoating
« Reply #4 on: January 13, 2011, 16:10:16 »
I think Wurth Undercoating is still available.  Check in the web, for Worth products.
Robert Hyatt
Williamsburg, VA.
Re: Undercoating
« Reply #5 on: January 14, 2011, 12:33:04 »
Wurth is no longer available. There were a few cans on Ebay last week but they are gone.
mbzse
Re: Undercoating
« Reply #6 on: January 14, 2011, 13:03:43 »
Quote from: zoegrlh
I think Wurth Undercoating is still available.  Check in the web, for Wurth products
I found this link for Wurth in the US:
http://www.servicesupply.com/
On this link, choose your country:
http://www.wuerth.com/web/en/wuerthcom/wrthweltweit/wrthweltweit_1/groupaddresses.php
These products below is what I use. I do not know if all Wurth Product ID are available in all markets
The rubber-based undercoating is Product No 0892 010
A good protective undercoating wax to go on top is Product No 0892 079
/Hans in Sweden
« Last Edit: January 14, 2011, 13:13:55 by mbzse »
/Hans S
georgefirst
Re: Undercoating
« Reply #7 on: January 15, 2011, 22:16:53 »
any  photo from  original  pagode. . .  or  any  from  congours  restore. .   l
mbzse
Re: Undercoating
« Reply #8 on: January 15, 2011, 23:00:21 »
Here is the underside of an original 280SL, off the Motoringinvestments.com website
Note the light body-schutz with remains of wax overspray (the dark brown areas), as
well as the basic primer grey-brown showing in the transmission tunnel area, and red spray unevenly
dimming and becoming less, from the sides towards middle of car.
Note: exhaust pipes have been renewed (replaced)
/Hans in Sweden
« Last Edit: January 15, 2011, 23:05:49 by mbzse »
/Hans S
IXLR8
Re: Undercoating
« Reply #9 on: January 16, 2011, 01:18:01 »
Hi--
Check out this 3M rubberized undercoating in Beige.
http://www.autobodytoolmart.com/3m-rocker-schutz-beige-08874-p-11268.aspx
I haven't used the beige, but the black is great stuff.
Joe
georgefirst
Re: Undercoating
« Reply #10 on: January 16, 2011, 21:31:55 »
    WHO  KNOWS  THE  ORIGINAL  THINK FOR UNDERCOATING. .
hkollan
  • Spain, Castilla-La Mancha
Re: Undercoating
« Reply #11 on: January 16, 2011, 22:20:28 »
For my 1971 280 SL project  I used a different 3M product for the undercoating.  It's called 3M 08800 Sprayable sealer.
It is best applied with a special spray gun from 3m(shown in the link) that gives a crinkle effect and with some practice you can
create a texture similar to the factory undercoating.
It's an amazing 2k product superior to anything else I've tried from Wurth and others.
Not cheap but worth it.
http://catalogue.3m.eu/en_eu/eu-aad/Sealers/3M_Sprayable_Sealer/Two_Part_Sprayable_Sealer/Two_Part_Sprayable_Sealer~08800
« Last Edit: January 16, 2011, 22:32:22 by hkollan »
Hans K, Cuenca, Spain
georgefirst
Re: Undercoating
« Reply #12 on: January 17, 2011, 18:05:37 »
  THIS  PHOTO  IS  FROM  MECHATRONIK  GERMANY.  HAT  ABOUT THE  UNDERECOATING US U CAN  SEE..
pj-tigger
Re: Undercoating
« Reply #13 on: January 17, 2011, 20:47:16 »
The BBB lists the underbody protection as being "Teroson Caoutchouc Underside Protection Antirombo 2021" , I did try to find out more about this but did not get very far. I ended up using http://www.wurth.co.uk/catalogue/pdfs/UK-CD_08_0566.pdf , this gave the closest finish to the original
Re: Undercoating
« Reply #14 on: January 22, 2011, 05:57:16 »
Hello hkollan,
That looks like factory texture to me! Very much the same as the Sekkens Product I used to use with the special spray gun
Joe
Re: Undercoating
« Reply #15 on: January 23, 2011, 05:07:50 »
The spray on bed liners seem to be pretty popular and so far I've only heard good things about it.  Anyone try any of this on their under body?
Raymond
  • USA, FL, Jacksonville
    • GemstoneMediaInc.com
Re: Undercoating
« Reply #16 on: January 23, 2011, 15:42:51 »
I have considered Dupli-Color Bed Armor.  It is water-based polyurethane with Kevlar.  It would be exceedingly durable.  The downside is it is only available in black but it is paintable.
dseretakis
Re: Undercoating
« Reply #17 on: January 28, 2011, 22:34:02 »
I think that bed liner might be a bit too stiff. MB undercoating is pretty pliable stuff that I have yet been able to duplicate. Texture duplication is a challenge but possible with several different products out there.
Raymond
Re: Undercoating
« Reply #18 on: January 29, 2011, 19:36:55 »
That's the difference with the Dupli-color stuff.  It's a water-based paint with Kevlar in it that remains pliable.
dseretakis
Re: Undercoating
« Reply #19 on: January 30, 2011, 00:11:41 »
Well I might have to try it out then!
