Author Topic: Cold Starting  (Read 2587 times)
Harry
  • USA, TN, Knoxville
Cold Starting
« on: August 22, 2022, 15:55:51 »
I know that I have seen on the Forum a great explanation of how the cold start process works on the 230SL but I cannot find that now.  (Aargh)  My wife would guarantee you that it is right in front of me and she would probably be right.  Never-the-less, can someone point me in that direction, please?
Thank you!
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
Re: Cold Starting
« Reply #1 on: August 22, 2022, 16:07:53 »
The first place to look is at Pagoda Notes - in the Technical Manual under premium content
Volume 2 issues No 2 and 3
You can also use the search function, I tried - "cold start" issue  Use cold start in quotes as shown and issue. I got four pages of hits, so you should be able to find some additional information.
Good luck
Harry
Re: Cold Starting
« Reply #2 on: August 22, 2022, 16:22:24 »
Thanks Jonny.  I always have some difficulty in searching because I get so many results.  Probably need to search against more discreet criteria.  And I did not recall about using the quotations around the search field.
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
