Author Topic: value clearance setting for engine M130.983  (Read 3904 times)
jesraymond
« on: August 08, 2022, 19:39:02 »
Can anyone tell what the clearance is for intake and exhaust value adjustments on 1970 280SL with M130.983 engine
MikeSimon
  • USA, OH, North Royalton
Re: value clearance setting for engine M130.983
« Reply #1 on: August 08, 2022, 20:18:31 »
Inlet 0.08mm  Exhaust 0.18mm if you work with standard non-metric tools  inlet 0.003 in exhaust 0.007 in
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
« Reply #2 on: August 09, 2022, 13:23:34 »
Mike is correct. The engine tech data decal in the tech manual is wrong.
jesraymond
« Reply #3 on: August 09, 2022, 16:04:52 »
Thank you
« Reply #4 on: August 10, 2022, 08:22:31 »
Fixed
« Reply #5 on: August 11, 2022, 06:03:32 »
What makes you so sure that these data were wrong?
When I added those as part of the Valve Adjustment Procedure (written together with Joe A.) I used as the source the Daimler-Benz "Technical Data for Passenger Cars" Issue 1969 and Issue 1971. Both show a value of 0.20 mm, see scans.
Did Daimler publish a revision later that you know of?
« Reply #6 on: August 11, 2022, 07:43:13 »
Interesting. All the tech data I've known here in Europe shows .08 and .18mm and that's what I've been using for 41 years.
Perhaps there's a difference in spec according to country?
« Reply #7 on: August 11, 2022, 16:40:47 »
Either way, the difference between the two specs on the exhaust side is .02mm or .0007". In reality, I doubt anyone using a feeler gauge will be anywhere near that close.
« Reply #8 on: August 12, 2022, 00:29:07 »
I doubt that Daimler-Benz used different values depending on the car's destination/location.
The German "Tabellenbuch" from 1968 shows the same 0.20mm value.
The English version is most likely a direkt translation from that one.
My preference for entries into our technical manual is to use the manufacturer's data when they are available.
That doesn't mean, of course, you should change your procedures that you used successfully for 40+ years.  ;D
As Wallace pointed out only a few would be able to "feel" the difference.
« Reply #9 on: August 12, 2022, 02:52:42 »
Well it is a "feeler" gauge after all. Some of us have more feelings than others.  ;)
