with our official
Pagoda SL Group logo
from our official partner.
No or Little Fuel at Injector Pump Cylinder One
Topic: No or Little Fuel at Injector Pump Cylinder One (Read 2922 times)
mBdrvr
Full Member
Senior
USA, PA, Bethlehem
July 23, 2022, 23:02:52 »
My engine is misfiring and smoking out the tailpipe, Cylinder 1 is the issue. Swapped plugs, injectors, & wires. Good compression.
Removed cylinder 1 fuel line at the injector pump. No fuel while cranking. Small amount at idle. Cylinder 2 (and the others) get fuel. The injector pump was rebuilt.
See link:
https://youtube.com/shorts/iT95P-wamZA?feature=share
Any ideas??
Last Edit: July 24, 2022, 02:49:42 by mBdrvr
Paul Greenblatt
'70 280 SL
'66 250 SE Cabrio
'60 190 SL
Full Member
Platinum
USA, OH, Blacklick
Re: No or Little Fuel at Injector Pump Cylinder One
July 24, 2022, 03:07:47 »
If the 19mm fitting on top of the injection pump for that injector line is not torqued tight enough, then that cylinder of the IP, may not pump fuel. On an M130 the torque is 21 ft./lbs. Be careful because over-torqueing it can damage the pump.
Kevkeller
Full Member
Silver
USA, HI, Honolulu
Reply #2 on:
July 25, 2022, 03:36:08 »
How long has your engine been unused? Maybe the piston is stuck in the up position? I had to take out the check valve and tap the piston down to loosen it.
1970 280 SL
mBdrvr
Full Member
Senior
USA, PA, Bethlehem
Reply #3 on:
July 25, 2022, 19:03:17 »
The car sat over the winter. Prior to that there was a puff of white/blue smoke on acceleration.
Lots of fuel was released after I removed the cylinder 1 pump port fitting and spring.
I didn't have the right tools to torque it down again. I'll try it tonight.
Paul Greenblatt
'70 280 SL
'66 250 SE Cabrio
'60 190 SL
mBdrvr
Full Member
Senior
USA, PA, Bethlehem
Reply #4 on:
August 01, 2022, 03:27:09 »
What’s the torque for the M129 FIP?
Paul Greenblatt
'70 280 SL
'66 250 SE Cabrio
'60 190 SL
