Author Topic: engine cooling upgrade on a 230  (Read 2097 times)
Figoulu
  • France, Languedoc-Roussillon, Villeneuve les Avignon
« on: July 20, 2022, 09:17:42 »
1965 230 SL
1991 Porsche 911/964 carrera 2
My youtube channel #lfgdf
Re: engine cooling upgrade on a 230
« Reply #1 on: July 20, 2022, 15:05:36 »
Oil coolers are generally not needed for the 127 engine. If you really need one, use the oil cooler system from a 250. It was available as an option for 230SL so would be considered correct for your car.
There are quite a few parts involved besides the cooler, oil filter housing, oil pipes to cooler, fitting on the side of the engine block for coolant hose, coolant pipe around front of engine, and Y shaped pipe near the thermostat housing.
1988 560SEC
Figoulu
« Reply #2 on: July 20, 2022, 19:18:45 »
Thanks a lot
The reason why I entered into that subject is that somebody adviced me to upgrade the coolant system… is he right ?
1965 230 SL
« Reply #3 on: July 20, 2022, 20:26:14 »
Several years back (18?) my mechanic sent my radiator out for a high-efficiency re-core. Has worked great since.
« Reply #4 on: July 20, 2022, 22:17:19 »
Hi Francois -
I think I remember your car having a manual transmission?  If so re-coring the radiator is pretty straightforward as there is no transmission cooler involved.
The standard radiator has a two-row core.  You should be able to get a good radiator shop to re-core your existing radiator with a 3-row core for added capacity.
Since you have a lift, it is easier to drop the radiator out from underneath.
Sounds like you are getting closer to returning your Pagoda to the road.  Our best to you and Patricia!
Figoulu
« Reply #5 on: July 21, 2022, 08:03:58 »
Hi Francois -
Hi Mike
It's been almost 1 year or so that we've been drinking champagne together at my house ! good memories !
My radiator has already been refurbished and a small leak cured. Apparently it's not the original one (a date from 20XX was stamped on it) but I couldn't figure out wheither it has 2 or 3 row core, I guess it's 3 but I'll chek it out...
My pagoda is far from being back again on the road...
1st I had a lot of Porsche and Harley's works to do, finished now
2nd As I'm progressing, I always find new stuff to adress, thninking that... "I couldn't leave it like this". Last thing I did was to plug some holes made on the chassis long time ago to put a trailer hook (!), as I removed the gas tank...
3rd since couple of weeks each week end (my main spare time) we have a very high temperatures that makes work into the garage simply impossible... we had up to 44deg For example I want to apply epoxy paint under the trunk before refixing the gas tank, but it has to be below 30 deg to make it properly. This morning it was already 26 à 7.30am :o
1965 230 SL
