Author Topic: Injection pump rebuild  (Read 4501 times)
mauro12
  • Italy, Sicily, Messina
« on: July 15, 2022, 14:04:51 »
Hi guys , finally I have rebuilt my inj pump after years of black smoke and huge fuel consumption. First impressions , the car is running very smooth with no stumbling or hesitation. Power is also more and there is no black smoke any more .
I have noticed only 1 thing , during hard acceleration and release of pedal , I hear the exaust popping a bit . Maybe is too lean ? Apart from that the car is running like a dream . I prefer not to touch anymore the pump or any other components . Thank you
Mauro Pisani
250sl 1967 5speed zf manual
Raymond
  • USA, FL, Jacksonville
    • GemstoneMediaInc.com
Re: Injection pump rebuild
« Reply #1 on: July 15, 2022, 16:23:20 »
Try depressing the clutch when you jump off of the gas and see if it does it then.  I vaguely recall a circuit on the 4-speed manual that was supposed to cut the fuel to reduce pops & pollution in the exhaust.  I don't have that on my Tremec 5-speed and haven't missed it.
roymil
« Reply #2 on: July 15, 2022, 17:33:14 »
Sounds like the lower solenoid may not be working, or possibly not hooked up after the rebuilt FIP was installed.  Here's a link to description of how that solenoid is supposed to shut off fuel to the system when lifting off the peddle when in 3rd, or 4th gears.   I see you have a ZF-5sp so wondering if it is setup to do that for 5th.    Either way its not a big problem other that wasting a bit a fuel, oh wait, yeah it is at these prices!  Enjoy that new pump...I have been so happy after rebuilding mine.
https://www.sl113.org/forums/index.php?topic=3277.msg46440#msg46440
Mark Miller
1968 280SL
Rode in his pagoda's first mile.
« Reply #3 on: July 15, 2022, 19:20:03 »
5 speed cars were never equipped with any switches on the transmission needed to make that system work. This is why they quit producing cars with 5 speeds for the US market after mid '69.
« Reply #4 on: July 15, 2022, 19:38:00 »
Great information...Mauro's car is an Italian delivery 5-Speed 250SL. So, how can he stop the popping/backfiring? Is it fuel or timing?
« Reply #5 on: July 15, 2022, 21:15:53 »
Not likely timing and it may be too rich. Go through the linkage tour and make sure your throttle plate is closing properly. Air entering the exhaust system is causing it to pop from unburned fuel. I would check spark plugs to see if there's a rich running condition.
« Last Edit: July 16, 2022, 01:05:57 by Benz Dr. »
« Reply #6 on: July 15, 2022, 23:18:08 »
Now if he can just understand all that, translate to Italian and then explain to the mechanic who put it all together for him…🤔
mauro12
« Reply #7 on: July 16, 2022, 08:10:56 »
I understood very well thank you . I guess there is a small delay in the linkage connected to the butterfly. By the way Hans fritzsche did a fanstastic job . He tuned my r22 pump for my 250sl by changing the space cam nr 22 to a space cam nr 8 . He has a special technology to equalize the amount of fuel in each cylinder with a mistake rate lower than 0.001 % . The engine is very smooth
Mauro Pisani
Runale
  • Malta, L-Iklin, Iklin
« Reply #8 on: July 16, 2022, 19:22:53 »
Would it make sense to have a look at the cold start valve too for any leakages..?
Alessandro
1967 250SL G050 G040
1979 W123 200D
2019 DB11 AMR
mauro12
« Reply #9 on: September 03, 2022, 14:51:59 »
I guess I will not touch anything . The car is running great and I’m curious to check the fuel mileage now . Before I was getting about 4km /l which is around 10miles per gallon .
Now after the perfect calibration done by Hans fritzsche , I believe should be around 20miles per gallon . He replaced the fuel delivery valves 1 and 4 , both bearings of the cam shaft , a new cam shaft , all seals and the calibration . Total amount was about 2700€. All done in 3 weeks time .
Mauro Pisani
whittakerturbeville
« Reply #10 on: October 10, 2022, 17:15:18 »
Yes. It's an absolutely mind-blowing setup.
RobSirg
« Reply #11 on: October 11, 2022, 21:26:28 »
My auto 280SL runs great, but l can readily make it pop/burble on deceleration……. especially when driving hard through the hills and shifting manually.
I guess it might be running too rich, but l kind of like it (esp. when the roof is down ☺️).
Rob
1962 E Type Jag BRG with Tan
1974 White Alfa Spider 2000
2023 Range Rover
1982 280TE (my daily)
1977 Yellow 911 Targa
1991 Nissan Figaro
1959 190SL Black
1970 300SEL 3.5
« Reply #12 on: October 12, 2022, 03:42:58 »
Rob
More likely a small exhaust leak. Air enters the exhaust and ignites the mixture inside the hot pipes when lifting off and coasting from higher RPM's.
mauro12
« Reply #13 on: October 13, 2022, 13:59:17 »
How to fix this exhaust leak ?
Mauro Pisani
Lori
  • USA, NC, Charlotte
  • 1968 280SL (US)
« Reply #14 on: October 13, 2022, 14:36:49 »
Mauro, first you have to identify where it it leaking.
https://www.sl113.org/forums/index.php?topic=35384.msg258587#msg258587
Lori
1968 280SL (US)
Bonnyboy
  • Canada, BC, North Vancouver
  • 1969 280sl Euro 4sp LSD
« Reply #15 on: October 13, 2022, 15:46:06 »
I had a popping on deceleration and found a small hole on the top of the exhaust where the two pipes are joined after leaving the engine. I bought a new pipe and as I was preparing to replace the pipe I decided to make sure that was the cause of the popping so I put a bit of muffler cement on to seal the hole and tried the car -  the popping on deceleration went away.   So maybe this winter I will put the new pipe on.
Worth a shot.
Ian
69 280SL
73 CB750K
75 MGB
78 FLH
82 CB750SC
83 VF 1100C
94 FLHTCU
96 F-150
08 NPS50
12 Pro 4X
