Author Topic: Windshield replacement W113 280 SL  (Read 3673 times)
Facelvega
  • Germany
« on: July 05, 2022, 06:44:40 »
I need to have the windshield changed because of a stone chip.
My question: what must be removed so that the installer of the glass company can perform the change?
I could read that the entire dashboard must be removed, which sounds rather unlikely to me.
Can anyone give me some advice?
Thanks Alfred
Jordan
  • Canada, ON, Jordan
Re: Windshield replacement W113 280 SL
« Reply #1 on: July 05, 2022, 10:39:05 »
It helps if the dash is out and makes the job a lot easier but it isn't mandatory. My dash remained in place and I had a glass installer do the work.  I made sure they had someone that was familiar with using rope to install the glass.
Marcus
66 230SL  Euro 4 speed
« Reply #2 on: July 05, 2022, 11:30:54 »
Ditto
Though if you can get the wood out at the corners, that reduces the chances of damage.
Get an MB seal, and if your ally trim is a bit under par for your car, it’s likely worth replacing that ( and the little centre cover) while the seal/screen is out
MikeSimon
  • USA, OH, North Royalton
« Reply #3 on: July 05, 2022, 13:13:06 »
Can you still buy the alloy surround trim anywhere?
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
dirkbalter
  • USA, CA, Corona
« Reply #4 on: July 05, 2022, 14:40:48 »
Yes, but expensive. (Niemöller, may be others).
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
Lori
  • USA, NC, Charlotte
  • 1968 280SL (US)
« Reply #5 on: July 05, 2022, 16:18:52 »
I got a quote from the classic center recently.  $380 (us) each side
Lori
1968 280SL (US)
Facelvega
  • Germany
« Reply #6 on: July 06, 2022, 16:06:23 »
thanks for all the advices. I will try to remove the wood and then visit the glazier to put a new pane. My AutoGlazier is a pro and has put in some difficult glass for me ( Facel-Vega, De Tomaso etc). I am confident.
« Reply #7 on: July 06, 2022, 17:37:49 »
It should be fine. I am a complete novice and helped a friend replace his Pagoda windshield succesfully recently. Only the fourth windshield I ever did. If you can re-use the current seal it should be even easier.
Desertpagoda
  • USA, AZ, Tucson
« Reply #8 on: July 26, 2022, 00:44:49 »
I agree with Cess, I roped one in today, with a 5ish year old seal. Fit/installed nicely. I would say, based on personal experience, avoid Euro brand. They fit like a saddle on a sow
kb
ChrisInNashville
  • USA, TN, Nashville
« Reply #9 on: July 26, 2022, 00:56:33 »
Good luck in the shipping…I had two sekurit windshields broken in shipping last year.   With supply chain issues, I had to settle for off brand aftermarket
‘69 280 SL
‘24 GLE450e
Tennessee, USA
