Author Topic: US front lights to EU front lights  (Read 3182 times)
BartSt
« on: April 20, 2022, 15:10:35 »
Is there a way you can change the US lights to EU lights if you have acces to the EU glass?
Has anybody changed the (inner) housing themselves.
Or is the housing completely different?
Main part to change is the blinker lights I presume ...
Curious if somebody tried this
Bart
Leester
  • USA, VA, Lorton
Re: US front lights to EU front lights
« Reply #1 on: April 20, 2022, 15:19:15 »
Yes, you can make the change but everything is different. If you take a look at any of the catalogs like SLS or Authentic Classics you can see the differences. Swapping them out is not complicated but few, if any, of the US parts are interchangeable with the euro parts and I can't think of any offhand that are.
Lee Backus
1963 220SE Cabriolet
« Reply #2 on: April 20, 2022, 17:44:44 »
Is there a way you can change the US lights to EU lights...Curious if somebody tried this...
Many times. You see, there are the purists here who believe the car was never meant to have many of the things it had for US specifications, such as side reflectors, side markers, bumper over riders, and sealed beam headlights.
Many have removed their US mandated items and restored the "design purity" back to the original Euro design. As noted by Lester, it's a complete change as everything needs to be changed, not just the front glass.
BartSt
« Reply #3 on: April 20, 2022, 19:17:39 »
Thanks.
I will smash my piggy bank
Bart
Leester
  • USA, VA, Lorton
« Reply #4 on: April 20, 2022, 19:37:44 »
Bart, I hope its a big piggy bank. As Mike points out a lot of things were changed on W113s, especially the later versions sent to the US. When I had the body work done on my July 1970 build I had them weld patches for the holes for the side markers and when I install bumpers they will be without the bumper guards. I will soon be installing an early version of the blue, red and gray heater slides. I'm in the process of working on the euro headlights too. One change that won't be made is removing the headrests since my wife views them as a must - and she's surely right about that.
I would like to "shiny up" some of the trim that was given a matte finish required by US DOT but still working on that.
Since I ended up practically building my car from the ground up, I've done a few other things like vented front brakes, not that I will be driving it that hard - just was easy enough to do.
I'm not really a purist, but I do enjoy the cleaner look of the earlier cars and everything I've done can be reversed if that's a subsequent owner's desire.
If you end up switching over to the euro headlights check out the Technical Manual and some earlier posts. You will have to unplug the wiring connector at the headlight and rearrange the wires in the connector to match up with the euro headlight electricals. Not hard to do.
Lee
Lee Backus
