Author Topic: Spark Plug Wires/Connectors  (Read 7512 times)
MikeSimon
  • USA, OH, North Royalton
« on: April 19, 2022, 15:17:21 »
The distributor on my 280SL has a mix of spark plug connectors. I need 3 of the original 90° plugs to replace 3 vertical ones a PO has installed. I take complete wires or plugs only.
It doesn't matter which wires, I will put the plugs on my wires.
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
m300cab
  • USA, Pennington New Jersey
Re: Spark Plug Wires/Connectors
« Reply #1 on: April 19, 2022, 16:53:26 »
i have a set I can sell you
Michael Parlato
MikeSimon
« Reply #2 on: April 19, 2022, 16:58:35 »
Perfect! pm sent!
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
German specs
3rd owner
« Reply #3 on: April 19, 2022, 17:33:58 »
Sorry to jump in: are the 90deg connectors correct or the straight ones?
I do not recall who exactly, but I remember statements about the straight ones being correct and I remember some degree of consent on that...
I did some digging after writing this (yes, my behaviour was unacceptably impulsive). There were both types used, as it looks here: https://www.sl113.org/forums/index.php?topic=12919.msg87587#msg87587
« Last Edit: April 19, 2022, 18:05:52 by Pawel66 »
TJMart
  • USA, NC, Matthews
« Reply #4 on: April 19, 2022, 18:21:40 »
Just went through the whole process of replacing my spark plug wires that were sold to me years ago by MB but were not correct. Both the ones sold by K & K and Authentic Classics now have 90 degree boots coming off the distributor. Because mine is a late model 280SL with the distributor plastic dust cover, I needed the straight boots for a proper fit. I replaced the new wires with straight boots. What a difference with the correct wires.
Tony
1970 280SL, 4 Speed
« Reply #5 on: April 20, 2022, 02:39:38 »
The distributor connectors for your 280SL engine should be right angle! At the spark plug connection, they should be straight.
« Reply #6 on: April 20, 2022, 05:17:05 »
That might be true but those 90 degree connectors have 1K resistors in them. I prefer the straight plug in wires instead.
MikeSimon
« Reply #7 on: April 20, 2022, 12:26:16 »
So, what's going on in your ignition system if you have 3 straight and 3 90° plugs? I drove the car like this for years and never recognized an issue?
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
German specs
3rd owner
« Reply #8 on: April 20, 2022, 13:06:51 »
Most 90 degree spark plug connectors are 5K ohms and resistance is not what you want or need on a points - coil system. Your mileage may differ.......
MikeSimon
« Reply #9 on: April 20, 2022, 16:17:06 »
Even if the car came like this from the factory?
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
German specs
3rd owner
« Reply #10 on: April 20, 2022, 18:19:47 »
If you wanted a perfect original car then you should make it that way. If you have a cover for your distributor cap then it would not matter so much.
« Reply #11 on: October 08, 2022, 10:40:37 »
Mike,  I messed around a bunch with wire ends until I found the proper Veso 1K ends for my US spec (Transistorized Ignition).  I may have a bag of Bosch and Beru ends in a drawer in my garage.  I'll look.
