Author Topic: 1965 230 SL Automatic Differential  (Read 2576 times)
Klaus Pieper
  • South Africa, KwaZulu-Natal, Westville
« on: April 09, 2022, 13:48:50 »
For no particular reason I wanted to feel the temperature of the differential on my 230 SL after 60 Km trip.  The diff housing was quite hot, one could touch it briefly, but only for a few seconds without getting one's hand burnt.  To me the temperature seemed high or is this normal?  The diff oil was changed with Castrol Axle EPX 80W 90 a few months ago to the correct level and the diff has no leaks.
Re: 1965 230 SL Automatic Differential
« Reply #1 on: April 10, 2022, 00:58:16 »
That's hot! Should be warm to the touch but not to the point where it would burn you.
Klaus Pieper
« Reply #2 on: April 10, 2022, 08:35:51 »
Thank you Benz Dr.  What could the reason(s) for the heat build up be?
