Author Topic: Parking lamps/ light swtich  (Read 6397 times)
« on: May 24, 2005, 09:56:22 »
On the '67 230 finback I learned to drive on, when one turned the light switch counter clockwise one stop, the right side parking lamps would illuminate, two stops, the left ones would illuminate.  To highlight your position when parked in narrow spots is what this was designed for.  Now my 1970 280SL has the exact same switch but nothing happens when I use these two stops (the owner's manual even points out that nothing will happen).  Anyone know when/why this feature left?  My newer BMW even has this feature.  Just curious.
Steve Griswold
1970 280SL signal red/bamboo leather, PS, 3.27 final drive gear ratio, AC, Becker Europa stereo,
Re: Parking lamps/ light swtich
« Reply #1 on: May 24, 2005, 14:38:27 »
I don't think this feature left. Have you checked the wiring connections/bulbs? Are there any other electric gremlins out there. I had a bunch on  mine, some of the connectors had the wires backwards, the grounding wire (brown generally) were not connected, etc. It took some good detective work (Thanks Ted G!) to get that all sorted out.
« Reply #2 on: May 24, 2005, 14:56:40 »
No other electrical problems, and it does specifically state in the 280SL owner's manual that those positions do nothing.  Strange to defeature a car, but they do that even with the new ones now, so perhaps this was the beginning of such a trend.  What does your owners manual say on the 250?  Do they work on yours?
Steve Griswold
« Reply #3 on: May 24, 2005, 17:17:02 »
I just checked the owners manual for my car, and it does state that the park lights, when the switch is rotated counter clockwise will engage. I have an early 250, and a correct 250 SL manual (not the later, combined 250/280 reprint). The lights do work correctly, but did not when I first got the car, hence the reference to the wires being switched around in the headlight connector block.
« Reply #4 on: May 24, 2005, 17:31:53 »
On my car the parking lights work, except in the front: My car is the US model and the light fixtures in the front don't have the parking light bulbs or the fittings for it. But the tail lights have them and it works just as you describe it.
113044-12-007537 (Jan '69)
« Last Edit: May 24, 2005, 17:33:57 by theengineer »
« Reply #5 on: May 24, 2005, 22:33:49 »
Steve,
If you do a search on "light switch" or some other key words, you will find lots written about this. Many people have found that a wire was simply disconnected.  If memory serves, the USA headlights may be wired differently than non-USA.  The search will tell all.
« Reply #6 on: May 25, 2005, 03:07:16 »
My '64 230SL Euro has the switch, it has the bulbs and the manual says how it should work, but none do, front or rear. The manual also says it is market dependent !
Where should one look for disconnected wires ?
« Reply #7 on: May 25, 2005, 04:44:16 »
Hi, Ben,
I have the same problem with my '65 UK 230SL (not that is running anymore  :x ).
Wiring diagram shows the wires running from the light switch to the bulbs direct (not fused) so I guess they may be tucked up behind the switch.
erickmarciano
  • Canada, Quebec, montreal
« Reply #8 on: May 25, 2005, 06:49:01 »
my 71 Euro German also does not work it drove me crazy but still did not find the problem
1971 280sl
1962 VW
1954 Allstate vespa
1958 gs150 vespa
1962 gs160 vespa
1994 E500 W124
1971 280sl
1989 Porsche 930 coupe
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
DavidAPease
  • USA, CA, Chico
  • Club Treasurer
« Reply #9 on: May 25, 2005, 15:44:15 »
Naj,
The parking lights are fused, though it's not immediately obvious how.  Fuse 1 feeds all of the "always hot" fused circuits on the car.  One wire from fuse 1 leads back to connection P30 of the ignition switch, which feeds through to connector Pa of the light switch, which powers the parking lamps.  (I've spent many hours pouring over the 230SL wiring diagram - sometimes I feel that I could just about draw it from memory!)
BTW, I have a very high-resolution scan of the 230SL wiring diagram that I've color-coded and annotated - NOT according to wire colors, but just arbitrary colors for different circuits so that I can follow them more easily.  The full diagram is almost 10MB (!), but I'd be happy to post it here if it's of interest.
-David Pease
'66 French 230SL
« Last Edit: May 25, 2005, 15:46:16 by DavidAPease »
-David Pease
« Reply #10 on: May 25, 2005, 16:06:45 »
Thanks for the correction, David.
Have emailed offline asking for a copy of the diagram.
thanks
