Author Topic: Gear box oil leakage  (Read 2611 times)
Timo AH
  • Finland, Central Finland, Vaasa
« on: March 23, 2022, 19:37:17 »
Hi, my 230 SL 66 gearbox is leaking oil a bit from the nut marked in attached picture. Is there any risk if I drain the oil and open it?
Timo
Re: Gear box oil leakage
« Reply #1 on: March 23, 2022, 21:40:35 »
That holds the reverse shaft in place so don't remove it. You can try removing just the nut and applying a bit of sealer before cleaning with brake cleaner. Seal the threads and back side of the nut and tighten securely. This would be a seeping type of leak so it shouldn't take much to stop it from leaking.
Timo AH
« Reply #2 on: March 24, 2022, 14:56:29 »
Thank you very much.
Timo
