Author Topic: Engine No. Plate  (Read 4046 times)
Charles 230SL
  • USA, GA, Griffin
  • 64 230SL
Engine No. Plate
« on: March 09, 2022, 17:14:15 »
hello all, Memmo is making a new Motor Nr./Engine No. plate for my 230SL/M127 and I can't find any posts regarding the "rivets" that attach the plate. Does anyone know, or have recommendations on where to get these rivets? thanks in advance, charles
Charles 230SL
  • USA, GA, Griffin
  • 64 230SL
Re: Engine No. Plate
« Reply #1 on: March 09, 2022, 19:14:39 »
I found the MB part number for the rivet at: https://www.sl113.org/forums/index.php?topic=9900.msg65257#msg65257. Unfortunately, appears "001476-003007" is no longer available. Any suggestions on how to best mount the plate so it looks reasonably correct?
« Last Edit: March 09, 2022, 19:42:42 by Charles 230SL »
« Reply #2 on: March 09, 2022, 21:18:24 »
Seems to me it is something like this: https://allegro.pl/oferta/nitokolki-niklowane-3-5x6-35-leb-kulisty-nit-8szt-9201596185?snapshot=MjAyMi0wMS0xOFQyMDo1NDowOS42MDFaO2J1eWVyOzRhNTM0ZDc5NmIwNmQwNTI3MzY0NGU4ZDA3ZmY1NDc0NGRiMDAyNjJkMGUyNGI2M2U5NzY0YTM3MmYyYjFmZDQ%3D
I do not remember the diameter - 3mm? 4mm?
Internet or local hardware store. The issue is you probably will be offered 1000pcs for a couple of dollars and you will be looking for a fellow Member to take some from you.
Charles 230SL
  • USA, GA, Griffin
  • 64 230SL
« Reply #3 on: March 09, 2022, 22:53:35 »
thanks Pawel, looks like Pelican Parts has them and if anyone else ever wants a couple, here's the link: https://www.pelicanparts.com/More_Info/001476003007.htm?pn=001-476-00-30-07-MBZ&fc=Y.  These 'Round Head Pins' also have a NSN: 5315-01-238-8949.
« Last Edit: March 11, 2022, 00:53:48 by Charles 230SL »
« Reply #4 on: March 09, 2022, 23:03:24 »
Authentic Classics have them.
Charles 230SL
  • USA, GA, Griffin
  • 64 230SL
« Reply #5 on: March 09, 2022, 23:20:43 »
« Last Edit: March 10, 2022, 03:31:47 by Charles 230SL »
mbpaul
  • USA, NM, Albuquerque, NM
« Reply #6 on: March 09, 2022, 23:32:49 »
My 1966 230SL, which I have had since new, has screws.  No rivets.  I do not think they were ever replaced but I guess they could have been although I can think of no reason for it to have ever been removed.
Charles 230SL
  • USA, GA, Griffin
  • 64 230SL
« Reply #7 on: March 10, 2022, 14:33:17 »
hello mbPaul, that's odd. Your Engine Number plate is secured to the side of the block with screws? I assume it's the original M127.981 engine? thanks, Charles
« Last Edit: March 10, 2022, 15:10:26 by Charles 230SL »
mbpaul
« Reply #8 on: March 10, 2022, 15:46:15 »
I screwed up.  I was talking about some other plate.  The engine plate is with rivets.
Charles 230SL
  • USA, GA, Griffin
  • 64 230SL
« Reply #9 on: March 10, 2022, 16:50:28 »
..The engine plate is with rivets..
  ok, thanks Paul.
« Reply #10 on: March 10, 2022, 21:27:44 »
They're called hammer rivets. Plenty of sources on line.
Charles 230SL
  • USA, GA, Griffin
  • 64 230SL
« Reply #11 on: March 11, 2022, 00:58:03 »
Mehmet finished my Engine Number plate and will post it tomorrow. I ordered a couple of "hammer rivets" (thanks Stick) from Pelican Parts in CA.
