Author Topic: Foggy rear window.  (Read 2978 times)
Pinder
  • USA, NJ, Edison
Foggy rear window.
« on: February 13, 2022, 02:37:38 »
Not sure why I could not find my prior post on a foggy (very foggy) rear soft top window. But ive spent several days on making it so I can see through it and with some great advice on here I have got it to work and the the procedure is the same as for wet sanding paint and it works! I will post a pic tomorrow but basically its the following process.
wet sand with 400/320 grit. 2 passes. (you will need 3m or similar 2 quarter sheets of paper and some washing up liquid)
wet sand with  600 grit. 2 passes
wet sand with 800 grit 2 passes.
wet sand with 1000 grit 2 passes.
wet sand with 1500 grit 2 passes.
wet sand with 2000 grit 2 passes
wet sand with Trizac 3000 2 passes.
use Migruires Plastice polish for headlight.
2015 BMW 320i xdrive
2021 Mercedes GLS450 Silver
Pinder
  • USA, NJ, Edison
Re: Foggy rear window.
« Reply #1 on: February 14, 2022, 01:06:28 »
Here is a before and after of cleaning a very foggy rear window.
Pinder
  • USA, NJ, Edison
« Reply #2 on: February 14, 2022, 01:08:29 »
The last step with trizac 3000 makes it clear and the polish finishes it off. It was heavily pitted in some parts but all the steps did the job.
AndrewB
  • United Kingdom, Channel Islands, Forest, Guernsey
« Reply #3 on: February 14, 2022, 09:09:53 »
Well done, and thank you for posting the pictures and your process
1969 280SL (unrestored)
1970 280SL (fully restored)
1971 Range Rover Suffix A Kingsley Restomod
1987 500SL
2002 Porsche 996 Targa
2011 Landrover Defender TdCi
2019 Mercedes S560 Cabriolet
