Author Topic: Passenger Door Pull  (Read 10015 times)
Charles 230SL
  • USA, GA, Griffin
  • 64 230SL
Passenger Door Pull
« on: January 31, 2022, 19:22:36 »
Hello all,
My passenger 'door pull' has been missing since I've owned the car and I'd like to try and install one without removing the door panel. Would anyone happen to know where I could find measurements for the red X's in my photo below? Installation of a passenger door pull has been discussed several times over the years but I can't find any measurements for the four screw holes. I want to make sure I get the holes marked correctly before I puncture the leather. thanks in advance for any info, Charles
dirkbalter
  • USA, CA, Corona
Re: Passenger Door Pull
« Reply #1 on: January 31, 2022, 19:39:56 »
Charles.
My panels are removed. Unless someone chimes in before, I can send some dimensions tonight.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
Jordan
  • Canada, ON, Jordan
« Reply #2 on: January 31, 2022, 20:47:00 »
Charles, have you tried feeling around the surface with your fingers?  If memory serves, the hardboard behind the vinyl/leather cover has holes in it where the door pull is screwed to the door.
Marcus
66 230SL  Euro 4 speed
MikeSimon
  • USA, OH, North Royalton
« Reply #3 on: January 31, 2022, 20:56:59 »
Isn't there a metal piece behind the panel, where the pull mounts to? Seems strange that it would pull at the panel.
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
Charles 230SL
  • USA, GA, Griffin
  • 64 230SL
« Reply #4 on: January 31, 2022, 21:21:59 »
..have you tried feeling around the surface with your fingers?  If memory serves, the hardboard behind the vinyl/leather cover has holes in it where the door pull is screwed to the door.
Yes, I've tried pushing in/around the area with my fingers but I can't detect any holes in the hardboard. I'll use a blow-dryer to heat the leather and see if I can feel the holes once the leather is more pliable.  Dirk, it would be great if you could post dimensions/measurements for the (4) holes. thanks in advance, Charles
mbpaul
  • USA, NM, Albuquerque, NM
« Reply #5 on: January 31, 2022, 21:58:33 »
Although there are no dimensions, if you go to ebay and look for "Mercedes 113 door panel", there are some pictures of used door panels with the holes shown.  Not exact but you can get a better idea of where the holes should be.
BobH
« Reply #6 on: January 31, 2022, 22:13:49 »
https://www.sl113.org/forums/index.php?topic=18284.msg155893#msg155893
Have a look here at post 1440. The door pull screws into these threaded holes in the frame, no dimensions, but the holes in the door lining need to line up with these threaded holes
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
Charles 230SL
  • USA, GA, Griffin
  • 64 230SL
« Reply #7 on: January 31, 2022, 23:22:29 »
thanks Bob, great photo from Andy Burns - I would have never found it.
The more I study the photos the more I realize I'd best go ahead and remove the door panel - looks too risky (punching through the leather and 'fishing' for those screw holes).  thanks again,, Charles
BobH
« Reply #8 on: January 31, 2022, 23:33:29 »
https://www.sl113.org/forums/index.php?topic=16914.msg119256
Hello Charles, if you're going to remove the panel, have a look at post 6 for a tip on how to mark the hole positions, probably the most fail safe method
Good luck!
UK delivered RHD
Blue soft top
Blue leather
dirkbalter
  • USA, CA, Corona
« Reply #9 on: February 01, 2022, 01:33:08 »
May be that helps. As Mike already said, you should be able to feel the soft spot
Let me know if you need anything else?
« Last Edit: February 01, 2022, 01:38:39 by dirkbalter »
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
dirkbalter
  • USA, CA, Corona
« Reply #10 on: February 01, 2022, 01:39:24 »
Mounting in the door
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
dirkbalter
  • USA, CA, Corona
« Reply #11 on: February 01, 2022, 01:47:41 »
And (new) panels.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
Charles 230SL
  • USA, GA, Griffin
  • 64 230SL
« Reply #12 on: February 01, 2022, 02:21:35 »
Outstanding! thanks Dirk!
« Reply #13 on: February 01, 2022, 03:22:30 »
I would recommend you check the condition of the threads in the door. When Mrfatboy and I were doing some work on the windows last year, I discovered that the threads were in pretty sad shape. I ended up going one mm larger as the threads were stripped out (using a sheet metal screw no less!). It was so iffy, that it was a standard warning for any passenger to never use the door pull. Now corrected., albeit with one size larger machine screw thread.
Charles 230SL
  • USA, GA, Griffin
  • 64 230SL
« Reply #14 on: February 01, 2022, 12:43:41 »
I would recommend you check the condition of the threads in the door..I discovered that the threads were in pretty sad shape.. I ended up going one mm larger as the threads were stripped out..Now corrected., albeit with one size larger machine screw thread.
thanks Jonny., yep, I thought about that (threads being stripped out). I'll be prepared to cut new threads in the door frame. The door frame appears to be aluminum in Dirk's photo - are the threads for the pull handle cut into aluminum or steel?
dirkbalter
  • USA, CA, Corona
« Reply #15 on: February 01, 2022, 15:33:24 »
Yes, checking the threads and repair if necessary is good advise. They are tapped into the aluminum.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
« Reply #16 on: February 01, 2022, 15:49:11 »
In my case on the door pull for the driver side which of course is also the armrest, I too had a situation where the threads were too weak and eventually stopped working. The whole thing just pulled out on one end.
The first repair done by my mechanic was with a steel rivnut. That worked briefly but eventually pulled out. For the second go around they brought out the big guns: using an aluminum welder they filled the hole completely and then re-tapped it.
The beauty of this repair was they were able to add more metal than was there originally thus giving more threaded area. So it’s a stronger fit now.
Charles 230SL
  • USA, GA, Griffin
  • 64 230SL
« Reply #17 on: February 01, 2022, 16:21:43 »
Well, since the threads are tapped into aluminum, they're most likely stripped out - which may explain why Bud's didn't install the pull handle when they trimmed/upholstered my interior 8 years ago..
I've got access to a TIG welder but I'd rather not strip the door down and attempt filling in the holes. Is there enough room to epoxy nuts on the backside of the frame and use screws to secure the handle? (I've not removed the passenger door panel yet and that's the reason for all the questions).
« Last Edit: February 08, 2022, 13:15:31 by Charles 230SL »
dirkbalter
  • USA, CA, Corona
« Reply #18 on: February 01, 2022, 16:58:41 »
The threads are M5 but I can check to be sure. If they are stripped I would just drill them out and tap M6 as suggested. It looks like there is enough room to clear the bigger bolt heads. There are other ways from rivet nut to threaded inserts…. Not sure I would start welding on a finished door.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
« Reply #19 on: February 01, 2022, 21:06:36 »
M5 helicoil will work just fine. I have used those in a few places in the cast door frame. Buy the set that comes with a drill, tap and inserts. One word of caution - use thread lube when tapping. The super soft door frame alloy will gum up the tap and wreck the threads when pulling the tap out. Ask me how I know.
« Reply #20 on: February 01, 2022, 21:10:52 »
I would have thought they are M4. M4 heli coil set will work just fine.
« Reply #21 on: February 01, 2022, 21:48:44 »
As I recall, the challenge with the rivnut on mine was that if you look at one, what holds it in place and prevents it from "spinning" is a very mild splining. Well, it really didn't take much torque (a/k/a shear  or twisting force) to rotate the rivnut in the now newer and larger hold drilled to accept it.  :(. Rivnut makes hex shaped rivnuts, but they require a hexagonal hole. I seem to have lost my hexagonal drill bit  :D; but their installation instructions say, "...laser a hex hole into your parent material..." Oh, yeah, I'll just go to the back and get the high powered laser to cut a hex hole...
Not certain why my shop didn't try a helicoil, I know that as a serious mechanic shop, body shop and restoration shop they surely had all of these "fixes" laying around.
The overriding issue here is the "parent material" that we're talking about--the door frame--is extremely soft material and doesn't put up with repeated installation and removal of screws. Otherwise we wouldn't be talking about this!
For many amateurs, the thought of bringing out a TIG welder on a finished door may be daunting. For professionals it was no big deal. Filled and re-drilled and re-tapped.
« Reply #22 on: February 01, 2022, 21:56:26 »
I used rivnuts in a lot of places requiring high torque fastening - never had any issues. The difference may be if they are aluminum or steel. But anyway it is not only the spline that holds them in place and prevents from spinning, it is more the crimping force applied during installation. You need to have proper riveting pliers (or what is the name of this device in English?).
I also do not think that the frame to which door handle attaches is a good place for rivnuts, particularly small diameter ones. They would be too short and the frame too thick to crimp them properly. These rivnuts work on metal sheet, not a bar type of frames.
I do not, however, recall seeing M4 rivnuts. I also think helicoil (or alike) is the best solution for the particular place in question. Or re-threading if possible.
« Last Edit: February 01, 2022, 22:03:59 by Pawel66 »
dirkbalter
  • USA, CA, Corona
« Reply #23 on: February 01, 2022, 22:27:12 »
As Paweł already said, you need proper pliers to “rivet” the nut in place. Just Pushing or pressing them in and rely on the splines for fastening is not going to cut it.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
dirkbalter
  • USA, CA, Corona
« Reply #24 on: February 02, 2022, 02:30:29 »
Just checked, Paweł was correct, the threads in question are M4.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
