Author Topic: oil leak from oil dip stick guide tube  (Read 3991 times)
georgem
« on: January 28, 2022, 21:01:37 »
I`m still on the hunt for leaks - my latest is a weep of oil from the base of the did stick tube where it enters the block. I gave it a tap in the hope that it would re seal it but this hasn`t seemed to work. Next thought was to remove it and seal it (JB Weld?) but I cannot get it out - help. Is it a tap in fit or does it have a thread?
George McDonald
Brisbane
230 Sl
1973 VW Kombi Single Cab Ute
Kevkeller
  • USA, HI, Honolulu
Re: oil leak from oil dip stick guide tube
« Reply #1 on: January 28, 2022, 21:05:50 »
I think there’s an o-ring that seals it.
1970 280 SL
« Reply #2 on: January 28, 2022, 22:40:32 »
Maybe take a look: https://www.sl113.org/forums/index.php?topic=21849.msg155723#msg155723
I went through some of the leaking places when I had a tour around the engine leaks a couple of years ago. Been through alternator support topic (also with the help of Joe and Dan), through some other bolts that protrude the block near the PS pump, PS reservoir support bolt, fuel lines front support bolt, etc.
« Reply #3 on: January 28, 2022, 23:56:33 »
Early tube may have an O ring but the late one doesn't. Press fitted, so it's in there tighter than you would expect.  I don't normally remove the dipstick tube unless I'm doing an engine bay detail. Only way to remove the tube, is from underneath, with the oil pan removed.
georgem
« Reply #4 on: January 29, 2022, 04:27:08 »
Thanks or all the responses.
So....as the engine is in the car it appears I have 2 options - try and tap (beat!) it further into the hole to try and seal it OR put something around the tube where it enters the block (what, I wonder). The oil isn`t under any pressure but it will look a bit agricultural unfortunately.
BTW, the end of the tube in the block - does it rest against any sort of stop or can it just keep going until tight?
George McDonald
Brisbane
230 Sl
« Reply #5 on: January 29, 2022, 07:41:55 »
Isn't the tube fitted into the oil pan? I think both styles of tube have depth limits on them. If it isn't in correctly, your oil level may be off.
hbrand
  • Edgewater
« Reply #6 on: January 31, 2022, 03:35:39 »
Use brake cleaner spry, then compressed air, the green thread locker will creep in and seal.
Greetings, Harold
georgem
« Reply #7 on: January 31, 2022, 10:49:39 »
Dan,
I tapped it with a block of hardwood and a hammer and it sounded solid against something so I guess its all the way in so the dip stick should be going all the way down
Harold,
Tell me more about this green thread locker - brand?
George McDonald
Brisbane
230 Sl
