Author Topic: 3.27 Rear  (Read 3250 times)
3.27 Rear
« on: January 08, 2022, 22:35:34 »
The current issue of The Star (Jan-Feb 2022) has an article by Pierre Hedary on doing this swap with new ring & pinion gears from MB instead of an entire donor axle.
It can be done on a 3.92 housing but not a 4.08.
The caveat at the beginning of the article is that this isn’t a task for amateurs but professionals only.
MarkCan
  • Canada, Ontario, Mississauga
Re: 3.27 Rear
« Reply #1 on: January 09, 2022, 00:59:53 »
I was glad to see that article as I am coming close to that stage. I would love to have full confidence but I have to admit there are some seeds of doubt. I’ll probably ask the masters here to give me a hand. I would love to do the job yet at the same time have the watchful eye overlooking the operation. Maybe I can book a day or two with Dan or Joe. 🤔
Re: 3.27 Rear
« Reply #2 on: January 09, 2022, 10:35:11 »
My 4.08 has been rebuild to 3.27 by a professional.
No issues, only the final adjustment of the pinion- Spacer sleeve I did myself to get rid of some whining.
Works fine and if you have a 280 with good engine no problem.
Re: 3.27 Rear
« Reply #3 on: January 09, 2022, 12:36:00 »
I would only install a 2.27 in a 280SL with a standard trans. The power to weight ratio between a 108 4.5 and the SL is very close which is why it will work well.
Re: 3.27 Rear
« Reply #4 on: January 09, 2022, 17:19:21 »
I have what was provided when the car was new. It's turning a rip-roaring 4,000 RPM at highway speed. Noisy as all get-out; I have to wear ear plugs on the highway rides of length. Hot as he** in the summer. I smell like petrol and oil when done. But isn't that the charm?
I was only reporting on the existence of the article, not the accuracy. Anybody wants any fun, tell Pierre Hedary that he's wrong... ;)
Re: 3.27 Rear
« Reply #5 on: January 10, 2022, 08:47:17 »
I look forward to seeing the article.  I was able to swap the 3.27 gears from one housing into my 3.92 housing because it gave me a reference point to measure the pinion depth and I was able to make a fixture that referenced off the side bearing race.  I wonder if he has the super rare factory tools or has he figured out another way to set it up?
Re: 3.27 Rear
« Reply #6 on: January 10, 2022, 08:52:28 »
My tools:
