Author Topic: Standing water in rear valence  (Read 2557 times)
Andrew Leach
  • United Kingdom, England, Oxted
  • 1968 280SL
« on: December 28, 2021, 22:49:21 »
Hello everyone,
10 months ago, I purchased a 280SL that has been extensively restored.  A few weeks ago, I got caught in a tremendous downpour and noticed a large puddle of water in the boot (trunk).  I subsequently traced this to faulty tail-light seals, which I've now replaced.  However when doing this job I removed the two rear steel cover plates, that provide access to the number plate lamps and noticed standing water (about 1cm) at the bottom of this compartment  - where the rear valence joins the body.  I can't see how the water made its way into this area.  Should there be drain holes in this section?  I haven't seen any reference to these in the posts about water leaks. Any thoughts would be most welcome.
Re: Standing water in rear valence
« Reply #1 on: December 29, 2021, 00:38:40 »
Not aware of a drain hole there...
First thought on source of water - type designation holes and/or "Automatic" sign holes - do you have them sealed?
« Reply #2 on: December 29, 2021, 04:29:19 »
Also just check where the number plate screws enter the rear panel they may also allow water to enter that cavity.
Andrew Leach
  • 1968 280SL
« Reply #3 on: December 29, 2021, 20:57:50 »
Hi - thanks for the advice.  Will take a look.  There's a small hole in the floor of the boot.  I think water must have dripped in from the tail lights, then found its way into this cavity, perhaps through this hole in the boot floor.  I've syphoned as much as I can and sprayed a load of wax into the cavity, so I hope that'll hold the rust at bay, but it's something to keep an eye on.
