Please check out joining the
Emergency Contact List
for help during your travels!
Body, interior, paint, chrome, and cosmetic items
Yellowing headlight
Topic: Yellowing headlight (Read 4053 times)
claret badger
Yellowing headlight
December 21, 2021, 14:18:46 »
Hi all,
I've had to replace one headlight with a brand new MB example. The problem is now that the old one looks yellow in comparison. Can anything be done? At £1,000 a pop for a new MB unit Im looking for an alternative! Any help greatly appreciated.
Full Member
Platinum
USA, CA, DeLuz and France, Haute-Marne, Guyonvelle
Re: Yellowing headlight
December 21, 2021, 14:22:18 »
Remove the glass and clean it?
David Robinson
Pagoda SL Board
Senior
Ireland, Connaught, Galway
Reply #2 on:
December 21, 2021, 16:01:28 »
Should clean up, if it doesn't come back to me as I should have one.
claret badger
Reply #3 on:
December 21, 2021, 17:52:44 »
It was suggested I'd need to buy another light and that it could not be 'cleaned'. Hence asking here.
I will give it a clean and report back.
BobH
Full Member
Platinum
United Kingdom, England, MALDON
Reply #4 on:
December 21, 2021, 18:36:23 »
There are lots of different glass cleaning products and compounds available for removing scratches etc, it's well worth a try, should be able to get it looking as good as new if you're lucky
Have a Google and watch some videos on the subject
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
AndrewB
Full Member
Senior
United Kingdom, Channel Islands, Forest, Guernsey
Reply #5 on:
December 28, 2021, 12:36:59 »
Is it the glass or the reflector that is showing yellow ? I have been able to buy replacement Bosch RHD headlamp glasses from Colin Ferns (stickandrudderman) - just the glass itself was less than £200 for 2. If it is the reflector, I believe one can re-silver these.
Colin is probably a good guy to call for advice on this
1969 280SL (unrestored)
1970 280SL (fully restored)
1971 Range Rover Suffix A Kingsley Restomod
1987 500SL
2002 Porsche 996 Targa
2011 Landrover Defender TdCi
2019 Mercedes S560 Cabriolet
claret badger
Reply #6 on:
March 12, 2022, 16:01:41 »
Well, finally removed the glass, and its not dirt sadly. The whole lens is very slightly yellow. Not sure if it was a tint from new, or just 55 years of aging, but looks like I need a new lens.
Pagoda SL Board
Platinum
USA, NC, Davidson
Reply #7 on:
March 12, 2022, 17:52:24 »
Assuming you are speaking of a Euro headlight, right? Isn't that a full glass cover, like real glass?
Are you saying the glass has yellowed?
claret badger
Reply #8 on:
March 12, 2022, 18:21:42 »
Look at the photo at the start. Yellowish hue all over. The car has been in US and Australia for half its life. Maybe that is relevant!
Full Member
Platinum
Australia, Victoria, Kyneton and Brisbane Queensland
Audit Committee
Reply #9 on:
March 13, 2022, 04:27:03 »
Had a similar thing, mine had been in Australia all its life. I had to replace both the glass and the reflectors.
1972 MB 280CE W114 Auto RHD 906G
Pagoda SL Board
Platinum
USA, NC, Davidson
Reply #10 on:
March 13, 2022, 13:39:15 »
You may never make the old match the new; different clarity or color in the glass from the start. But, try this:
https://www.hunker.com/13423434/how-to-clean-yellowing-glassware
Also, you may seek out a mild cleanser that contains oxalic acid; in the USA this would be “Bar Keepers Friend” which is available everywhere.
But a perfect match may require two new, or two old lenses.
Pinder
Full Member
Platinum
USA, NJ, Edison
Reply #11 on:
March 15, 2022, 01:38:23 »
try soaking it in bleach overnight
1970 280 SL Light Ivory DB 670. 4 Speed manual shift no AC Limited Slip Diff.
2015 BMW 320i xdrive
2021 Mercedes GLS450 Silver
Desertpagoda
Associate Member
Silver
USA, AZ, Tucson
Reply #12 on:
July 26, 2022, 00:58:41 »
Just buy a new lense, it will be MUCH closer in color
kb
Yellowing headlight
