Author Topic: pads at top of windshield  (Read 2913 times)
Lori
  • USA, NC, Charlotte
  • 1968 280SL (US)
« on: December 08, 2021, 18:35:25 »
I am looking to repair and recover the foam pads at the top of the windshield. Any recommendations on what to use to repair the ripped, dry foam around the hardtop/softtop connections where a previous owner I guess had trouble installing/removing the hardtop.
Lori
1968 280SL (US)
johnk
  • USA, OH, Avon
Re: pads at top of windshield
« Reply #1 on: December 12, 2021, 12:29:09 »
Heritage used just a little bit of body filler to repair my dash pads before they covered them.
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
« Reply #2 on: December 12, 2021, 13:23:51 »
Body filler is also commonly used to fill cracks in the tops of dashboards before recovering or painting.
« Reply #3 on: December 12, 2021, 22:13:48 »
Hello Lorsar,
Personally I think the rcommendation of JohnK works out best.
I would not use body filler to replace the missing material. That would turn out to be too solid or stiff and can crack when the two lock pins of the softtop frame come too close to the repair area if the softtop isn't aligned superbly. I would rather recommend using a semisoft material - foamy for instance - very much as the original material is. Always try to repair with the same type of material your work area is composed of. Maybe the black window sealant (semisolid rubber-like sealant) would also work well.
Finally, I would repair this with liquid leather or leather crack filler - see the products of leatherique.com or equivalent.
Personally I think the recommendation of JohnK with recovering with new vinyl after adequately filling will work out best.
« Last Edit: December 12, 2021, 22:33:51 by 114015 »
Lori
  • 1968 280SL (US)
« Reply #4 on: February 03, 2022, 23:00:39 »
I ended up using lightweight spackle.  It dried firm but with  a little spongyness.
Lori
1968 280SL (US)
