Author Topic: Bracket for linkage rod for 230 SL  (Read 6723 times)
Figoulu
  • France, Languedoc-Roussillon, Villeneuve les Avignon
« on: October 22, 2021, 16:24:50 »
Mine has been eaten by unfortunate acid bath…
1965 230 SL
1991 Porsche 911/964 carrera 2
My youtube channel #lfgdf
Re: Bracket for linkage rod for 230 SL
« Reply #1 on: October 22, 2021, 16:43:07 »
One of the options is Mercedes dealers, A 127 070 20 24, ca EUR 150-170.
SLS EUR 130.
Figoulu
« Reply #2 on: October 22, 2021, 17:20:22 »
Thanks Pawel !
I saw already new parts but more expensive on other sites.
I was looking for old good original Mercedes part as I’m always reluctant to buy refabrication…
1965 230 SL
Bill Sgro
  • USA, FL, Bradenton
« Reply #3 on: October 24, 2021, 14:38:46 »
If the bearing is still good, you might try polishing it.  The aluminum should polish up very nicely.
1970 300SEL 3.5
johnk
  • USA, OH, Avon
« Reply #4 on: October 24, 2021, 15:35:31 »
I would try eBay. I was amazed at the misc parts I could find.
John Krystowski
Avon Ohio
2008 E350
2007 GL 450
2019 BMW 540
Figoulu
« Reply #5 on: October 24, 2021, 16:09:01 »
It’s been eaten at the shop. Some small part of metal is missing… I guess it’s not aluminum but maybe zamac
1965 230 SL
Figoulu
« Reply #6 on: October 24, 2021, 16:10:11 »
Tried already. I agree 👍
1965 230 SL
« Reply #7 on: October 24, 2021, 20:34:17 »
Just for future reference - when you go put on this / a replacement bracket, those small nuts go on the opposite direction. The little 'cones' help center the bearing onto its mounting place 'just right'. Apparently it does make a difference.
MarkCan
  • Canada, Ontario, Mississauga
« Reply #8 on: October 24, 2021, 23:53:14 »
You may save the original. Try dry blasting it first to remove the damage and oxidation than low pressure glass beads/vapour honing may do the finishing trick. I was able to save quite a few pieces that way.
Here are 2 examples;
Figoulu
« Reply #9 on: October 25, 2021, 05:22:43 »
I have some doubts due to the deterioration of the upper part of it
1965 230 SL
Figoulu
« Reply #10 on: October 25, 2021, 05:30:05 »
On the part catalogue its seems assembled as my bracket is :o
1965 230 SL
« Reply #11 on: October 25, 2021, 16:37:52 »
The conical end of the nut is there to center the nut vs. Bracket. The conical ends go towards the bracket.
« Reply #12 on: October 25, 2021, 19:29:18 »
I probably have one of those things. I would recommend new bushings at both ends.
Figoulu
« Reply #13 on: October 25, 2021, 19:59:39 »
Fine !
Any offer by pm?
1965 230 SL
« Reply #14 on: October 25, 2021, 20:22:07 »
bushings easy to buy at MB.
