Author Topic: Rad to heater pipes and hoses RHD  (Read 5052 times)
Esmo
  • United Kingdom, Wales, Conwy
  • SL 230 1967
« on: September 27, 2021, 08:23:16 »
Hello, I would appreciate any help re the position of the black metal Y pipe ,other black pipe and all connected hoses for my 1967 SL230. I’ve read the LHD Info on the forum but cannot work out the layout for my RHD.
Re: Rad to heater pipes and hoses RHD
« Reply #1 on: September 27, 2021, 18:25:18 »
I think I know what you're talking about but your picture isn't sufficiently informative.
gordon
  • United Kingdom, England, Burntwood
« Reply #2 on: September 27, 2021, 21:07:12 »
Hi Esmo, do the attached photos help, 1964 230 SL
Esmo
  • SL 230 1967
« Reply #3 on: September 28, 2021, 05:07:52 »
Hello Stick , Thanks for your reply , tricky to explain but I’m trying to work out the correct layout of the two black pipes and connected hoses . That’s from the bottom of the main radiator to the heater matrix, rad reservoir and thermostat housing RHD. I know the route of the 8mm hose from the top of the main radiator to the top of the tank and the large hoses from the main radiator . Any help would be appreciated.
Esmo
  • SL 230 1967
« Reply #4 on: September 28, 2021, 05:10:03 »
Hello Gordon     Thanks ,great photo ,your car looks fantastic, more pics of the pipe layout would be appreciated.
« Reply #5 on: September 28, 2021, 06:56:18 »
Do these help ‘65 RHD
I have others if you ask.
Esmo
  • SL 230 1967
« Reply #6 on: September 28, 2021, 15:31:01 »
G’day Garry
Great photos your engine looks stunning, any more photos in particular if you have any of the engine bay when the engine was first removed . Also any others showing the two black metal water pipes would be greatly appreciated, thanks for sharing your photos.
« Reply #7 on: September 28, 2021, 22:32:33 »
I am not quite sure where you are referring to whether it is around the water pump and below or further down FIP side. Here are a couple more.  I only have the one on the empty engine bay.
Esmo
  • SL 230 1967
« Reply #8 on: September 29, 2021, 05:46:56 »
Thanks for all the photos very very helpful , the two black metal water pipes are pictured on the attached photo and any further details would be appreciated.
« Reply #9 on: September 29, 2021, 06:47:30 »
Esmo,
Are you sure they were black on original cars.
gordon
« Reply #10 on: September 29, 2021, 09:41:47 »
Hi again, here are some more photos. The pipe with the  Y shape passes under the inlet manifold ( and is clamped to the inner wheel arch) and emerges below the servo. The lower branch is then connected to the other pipe with a short rubber pipe and continues to the underside of the coolant expansion tank. The upper part of the  Y shaped branch on the first pipe then goes to the fire wall. The tab on the second pipe bolts to the fire wall behind the cylinder head.
gordon
« Reply #11 on: September 29, 2021, 09:43:39 »
Another
gordon
« Reply #12 on: September 29, 2021, 09:44:35 »
Another
gordon
« Reply #13 on: September 29, 2021, 09:46:34 »
Another
Esmo
  • SL 230 1967
« Reply #14 on: September 29, 2021, 10:08:49 »
Hello Gordon
Thanks for that great photos and explanation .
Duncan200
« Reply #15 on: March 11, 2023, 10:10:06 »
Hello All,
To save starting a new topic, I thought I’d try asking on this one first.
I have a RHD 230 and I’m trying to find the part number for the pipe I’ve circled in red.
It connects to the y pipe then runs across the firewall to the coolant expansion tank.
 I’ve copied the photo supplied in the post as my car is in bits. Credit due to the owner (Gordon), your car is in way better condition than mine at the moment.
If anyone can help me with a part number that would be a good start to the challenge of finding one.
Thanks Doug.
2000 MB CLK430 Convertible
2001 Nissan 200SX Spec S
2019 Audi SQ7 Special Edition
Esmo
  • SL 230 1967
« Reply #16 on: March 11, 2023, 13:00:27 »
Hi Doug I think the Y pipe is 1138300115 LHD and 1138300215 RHD ,I’m unsure if the pipe your asking about is handed as I can only find reference to 113 831 05 85 , I would recommend you confirm it’s correct for your RHD before ordering .
Happy to be corrected as not 100% sure.
Les
BobH
« Reply #17 on: March 11, 2023, 15:01:56 »
The pipe that runs from one branch of the "Y" pipe along the firewall to the expansion tank on a RHD car, i think is part number 113 500 0072.  Niemoeller have it listed as no longer available.  Not sure if any other suppliers have it
https://www.niemoeller.de/en/w113/w113/B042/500
February 1965 230SL Automatic
UK delivered RHD
Blue soft top
Blue leather
Duncan200
« Reply #18 on: March 11, 2023, 21:31:55 »
I thought I’d gotten lucky when I found the “Y” pipe and ordered it from Authentic Classics last year.
Upon pulling the old ones down from the shelf it is different.
Looks like I’m up a certain creek without a paddle when it comes to finding these.
The old RHD difference has stymied me again.
I’d reuse mine, but the flares have corroded.
Bob you are right, I didn’t scroll far enough down on the Niemoller website to see the picture.
The two pipes needed are 113 500 00 72 and 113 830 02 15
Not sure what to do now.
DaveB
« Reply #19 on: March 11, 2023, 23:17:38 »
It should be straightforward for a radiator shop to braze new ends onto that pipe, if the rest of it is ok.
DaveB
'65 US 230sl 4-speed, DB190
Duncan200
« Reply #20 on: March 13, 2023, 10:15:36 »
Hi Dave,
I thought that, just not 100% sure on the integrity of the rest of the pipe.
It’s been 3 years since they’ve been under pressure.
I’ll get a radiator shop to have a look and pressure test them if possible.
I think I might ask my plumber cousin if we can make something up in copper, a coat of satin black and no one will know any different.
Doug
« Reply #21 on: March 13, 2023, 15:55:14 »
It's a fairly easy fabrication job if you can find the right outfit to do it.
