Author Topic: Rebuild engine 230sl, M127, sequence of crankshaft bearings  (Read 2640 times)
BartSt
« on: September 21, 2021, 11:11:54 »
All,
Is this the correct placing of the bearings or should I move bearing 2 (with the thinker border) to place 3?
Hope you can give some guidance.
Bart
BartSt
Re: Rebuild engine 230sl, M127, sequence of crankshaft bearings
« Reply #1 on: September 21, 2021, 20:29:43 »
Nobody knows?
Sead
  • Bosnia and Herzegovina, Federation of Bosnia and Herzegovina, Sarajevo
« Reply #2 on: September 22, 2021, 12:21:06 »
Nr2 is correct.
1964 230SL
BartSt
« Reply #3 on: September 22, 2021, 21:07:39 »
Thank you!
« Reply #4 on: September 24, 2021, 04:44:09 »
Yes #2 main bearing has the "thrust surface" built into the bearing and must be fitted to the thrust surface of the crankshaft. The thrust clearance should be checked. Normally if the crankshaft is to be ground, the thrust surface is also ground and the original clearance restored. With undersize main bearings the thrust flange is wider and thicker, so the crankshaft (thrust surface) can also be ground to specs.
