Author Topic: Inlet manifold heat shield 230 SL  (Read 2399 times)
gordon
  • United Kingdom, England, Burntwood
« on: September 16, 2021, 12:36:11 »
From the attached picture do I need to bend the end portions down and the rear parts upwards.  I guess it needs to be fed in after both manifolds are bolted up then the throttle link poked up from below.
Re: Inlet manifold heat shield 230 SL
« Reply #1 on: September 19, 2021, 05:33:54 »
At the exhaust manifolds, the aluminum turns upward. At the intake manifolds the aluminum turns down.
