Author Topic: Removal pins which hold chain guides (front of engine block)  (Read 2913 times)
BartSt
« on: September 01, 2021, 11:34:24 »
All,
How do I remove the 2 pins (per chain guide)?
Is this the method?
Bart
450sl
Re: Removal pins which hold chain guides (front of engine block)
« Reply #1 on: September 01, 2021, 12:23:24 »
yes
« Reply #2 on: September 01, 2021, 15:15:18 »
I like to run a tap down the threads before I start. Nothing like breaking a  screw off in one of those pins.  >:(
« Reply #3 on: September 01, 2021, 15:56:59 »
I use a slide hammer that I made 35 years ago from an old cylinder head bolt with the end turned down to M6 and a lump of round bar about 70mm diameter and 30mm thick as the hammer.
UJJ
  • USA, CA, Grass Valley
« Reply #4 on: September 02, 2021, 13:57:16 »
Don't you have to remove the radiator in order to use a slide hammer?
Urban Janssen
Grass Valley, CA
1968 280 SL - 4speed manual
173 anthracite grey
« Reply #5 on: September 03, 2021, 15:54:45 »
No, but it is wise to put a sheet of metal in front of the radiator so you don't damage it.
