Author Topic: 1969 280sl engine installation tips  (Read 4920 times)
edwardburak@erols.com
  • USA, VA, Marshall
« on: August 13, 2021, 19:20:23 »
I recently installed a motor and transmission in a 1969 280sl. I did it with the transmission and engine connected.
I had a variable-angle adapter for my engine hoist, but it was still difficult getting everything lined up.
What is the best advice, install the two together or one by one?
If installing them separately is the best route, would you go trans first?
I have another installation I will be doing in the near future.
thanks
Re: 1969 280sl engine installation tips
« Reply #1 on: August 13, 2021, 19:23:10 »
Best I recall (this was around 2004) I installed my rebuilt engine together with the transmission and I did not have an 'angle-widget' but it went in fairly uneventfully anyway.
« Reply #2 on: August 13, 2021, 19:36:11 »
We install them connected together.
MikeSimon
  • USA, OH, North Royalton
« Reply #3 on: August 13, 2021, 19:45:36 »
If you hook the engine up to the lift the way it is supposed to, the two units together will tilt with the transmission down in the back and go in and out fairly easy.
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
« Reply #4 on: August 14, 2021, 00:03:18 »
You need about a 45-degree angle as the engine is placed into the bay. I place the back of the trans on a small floor jack so that the assembly can move backward. Once the engine clears the front nose panel then we drop the front of the engine until it's level. Raise or lower the floor jack so that the drag link is cleared and then fit the engine mount arms to the engine mounts. I only attach the manifolds after I have the starter wires hooked up and the throttle linkage in place. Do not install any throttle linkage until you have the engine placed or you can bend parts or damage the aluminum bearings on the firewall.
I tend to leave the grill screens off until I have the engine in. The power steering pump can get caught on the screen and easily damage it.
col320ce
« Reply #5 on: August 14, 2021, 09:44:53 »
I'm doing mine tomorrow ... I took it out from underneath and will pop it in the same way as my subframe has all its bits disconnected.  I'll take pictures of my Laurel and Hardy sketch tomorrow if you like.  I also don't have an engine lift/stand and didn't want to get one for one use but I have a hoist so that was part of my reasoning for doing it this way.
Col
1964 230SL
1965 250SE coupe
1993 320CE Sportline
« Reply #6 on: August 16, 2021, 12:19:29 »
Transmissions are so light it is really not hard at all to pop it up later.
FresnoBob
  • USA, CA, Fresno
« Reply #7 on: September 07, 2021, 17:54:01 »
I have done both ways and highly recommend installing them attached together.  It is very difficult to install at the upper bolts connecting the transmission to the engine once the engine is installed.  Slow and easy works well!
Bob Comstock
1966 230 SL Euro Auto
2017 AMG C43 Cabriolet
Leester
  • USA, VA, Lorton
« Reply #8 on: September 08, 2021, 12:19:56 »
I did mine bolted together earlier this year. I second leaving throttle linkage out. If your driveshaft is still in and connected at rear, make sure its out of the way, my transmission mounting bracket snagged mine and got a bit hung up - not a disaster but for sure a PITA. Or leave out the mounting bracket - its easy to install afterwards.
Lee Backus
1963 220SE Cabriolet
dirkbalter
  • USA, CA, Corona
« Reply #9 on: September 08, 2021, 15:14:19 »
I have this task ahead of me. Did you guys install the unit with the manifolds (intake / exhaust) bolted on? Or after installation? Same question for the pump?
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
  • USA, VA, Marshall
« Reply #10 on: September 09, 2021, 12:23:20 »
I installed mine with both the intake and exhaust manifolds mounted. Those were not a difficulty for me. I had trouble getting the entire engine and trans at the right angle and keeping the valve cover from hitting the firewall.
thanks for the help
Leester
  • USA, VA, Lorton
« Reply #11 on: September 09, 2021, 14:11:50 »
I installed with intake and exhaust manifold not installed. Pump? I installed with FIP installed but water pump not installed, power steering pump not installed. I would leave off the bracket for the transmission mount (in my case standard trans) and make sure your driveshaft is well out of the way.
I too had a problem with the valve cover hitting the firewall and ended up putting padding between them. Even with that I put a small dimple on the firewall. Getting the "angle of the dangle" just right is tricky.
Lee Backus
dirkbalter
  • USA, CA, Corona
« Reply #12 on: September 09, 2021, 15:38:43 »
Thank you both.
Based an that, I guess it would make sense to keep the valve cover off to gain an inch or two.
I have my engine / trans on a dolly right now and I am fitting all the components prior to installation to insure everything is sound. Naturally, I only want to take off as little as necessary afterwards.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
mikeswplt
  • USA, TX, Lago Vista
« Reply #13 on: December 11, 2021, 15:10:03 »
What lift points did you use to hoist your engine? I’m getting ready to install my engine/transmission back into my 250SL.
‘68 250SL    under restoration
‘11 RR Sport
‘22 Silverado 2500HD
‘95 F355 GTB
dirkbalter
  • USA, CA, Corona
« Reply #14 on: December 11, 2021, 16:10:42 »
Take a look at the pictures. Make sure you can get high enough if you use a cherry picker. My buddy JonnyC can up to help. Great to have two people looking.
It went surprisingly smooth and fast.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
mikeswplt
« Reply #15 on: December 11, 2021, 19:33:59 »
Thanks for the pictures Dirk, just what I was looking for. Engine looks beautiful, just got mine back from
Metric Motors.
‘11 RR Sport
‘95 F355 GTB
dirkbalter
  • USA, CA, Corona
« Reply #16 on: December 13, 2021, 17:55:09 »
Metric Motors.
Yup, mine is from Metric too. He does a nice job. Make sure (as mentioned above) you can tilt the engine enough. A second person is very helpful.
Good luck
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
