Author Topic: Heater Motor Mounting Grommet PN?  (Read 3953 times)
captainslow
  • USA, OR, Scappoose
« on: July 19, 2021, 12:54:00 »
Does anyone know the MB part number for the grommets being used as motor mounts for the heater motor?  I've combed through a number of websites and this forum and I can't seem to find it.  I would be remiss if I put it back together without new rubber!  Not a job I want to do a second time!
Re: Heater Motor Mounting Grommet PN?
« Reply #1 on: July 19, 2021, 20:38:07 »
There is a grommet for the wire cable there, pn A 000 997 18 81, 1 piece.
Motor mounts - this could be 3 pieces of this: A 000 835 01 93, installed as of ident. no.: 044 017154. I think they are NLA, but you may ask dealer, maybe they are replaced with something. I do not see them available neither at SLS nor Niemoeller.
dirkbalter
  • USA, CA, Corona
« Reply #2 on: July 19, 2021, 21:12:02 »
If its the rubber mounts you are looking for, I have the blower box out. My mounts still look ok. If you don't have the old ones any more, I can give you dimensions and you can order generic ones from parts store or amazon.....
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
captainslow
« Reply #3 on: July 20, 2021, 05:20:42 »
I don’t want you to compromise your mounts to get the measurement! That is the main reason I did not pull mine apart. To be honest they look suspiciously similar to the grommet that holds the cable into the plastic air control flap…
