Author Topic: Sway Bar Bushings - How Tight?  (Read 7249 times)
« on: April 30, 2005, 08:46:50 »
I just replaced my sway bar bushings.
 :?:  :oops: Question:  How much do I tighten down the nut (long bolt) on each side?  How much do I squish these new rubber donuts?
Thanks!
Memphis, TN.
1997 E320
Re: Sway Bar Bushings - How Tight?
« Reply #1 on: April 30, 2005, 09:04:00 »
You do squish them a bit. I believe 23 mm of bolt should show.
Vince Canepa
« Reply #2 on: May 02, 2005, 05:51:25 »
Tighten them all the way.  Note that one of the bolts has flats on the end.  Don't allow this to turn.  It is an eccentric that is used to position the front crossmember.  Some alignment techs used it to adjust the caster, but I think the original purpose was to set the wheelbase equal on both sides as part of an alignment.
Vince Canepa
113.043-10-001543
568H Signal Red
116 Caviar MB-Tex
« Reply #3 on: May 02, 2005, 11:40:20 »
 :) Update!
I found the spec in the BBB (32-0/15).
See attached pic. Jim, you are correct 23 +- 1mm.
Thanks!
Download Attachment: torsion bar.jpg
37.51 KB
Memphis, TN.
1997 E320
« Last Edit: May 02, 2005, 11:41:17 by bpossel »
« Reply #4 on: May 02, 2005, 14:00:43 »
Aren't books great?
« Reply #5 on: May 02, 2005, 14:09:17 »
Originally posted by rwmastel
Aren't books great?
I tend to think so....
James A. Huber,
Sierra College Librarian
