Author Topic: A very long shot - The story of a spring  (Read 2981 times)
BartSt
« on: July 06, 2021, 18:43:04 »
All,
It started 3 weeks ago with a major decision in my 230SL (1967) life. I was going to take the engine out and check piston no1. and no2. (lower compression then the rest)
Today I put the engine on the engine stand (with the head already removed) and started to take bits and pieces off. Like FIP, Waterpump, several pulleys etc.
When I turned the engine up side down, the small bit which links to my (123) ignition dropped out (no scratches etc) but it was an uncontrolled move from me ...
After 5 min I saw a spring on the floor ... and that is where the mystery starts ...
I do not have a clue where it came from ... from the Fuel Ignition Pump, from the ignition ?
Here is a pict.
As I told you ... this is a long shot ... but who knows ...
Be safe,
Bart
mrfatboy
  • USA, CA, Rancho Santa Fe
    • Mrfatboy
Re: A very long shot - The story of a spring
« Reply #1 on: July 06, 2021, 19:22:39 »
Here’s my guess 🤷‍♂️🤣
1969 280sl (Aug 1968 build)
Signal Red
4 Speed
« Reply #2 on: July 06, 2021, 20:24:21 »
Quote
Spring (below) ignition distributor: A127 993 0101
Goes between helical gear and distributor.  8)
Rahul
  • Bermuda, Devonshire, Paget
  • 1971 280SL automatic #571, parchment
« Reply #3 on: July 06, 2021, 20:33:05 »
Appears there is no such thing as a 'long shot' on this site!!
1971 280SL auto #571 over parchment
« Reply #4 on: July 06, 2021, 21:38:28 »
Yeah, it's the distributor spring. Keeps a bit of positive pressure on the gears.
BartSt
« Reply #5 on: July 07, 2021, 05:51:12 »
You guys are .... incredible ...
Thank!
