Author Topic: 0 231 116 066 Bosch distributor ?  (Read 5106 times)
MarkCan
  • Canada, Ontario, Mississauga
« on: June 29, 2021, 17:00:27 »
I was about to purchase the Pertronix pickup to get some testing done and I was told by their support team that there isn’t one. The unit listed below, is for the previous versions of distributor and specifically 051.
https://pertronixbrands.com/products/pertronix-91863-ignitor-ii-adaptive-dwell-control-bosch-6-cyl?variant=31797071740964
I would like to know if there are differences in size or points attachment between the 2 distributors (066 and 051)
Re: 0 231 116 066 Bosch distributor ?
« Reply #1 on: June 29, 2021, 18:01:19 »
I believe they might be different. If it's an aluminum distributor then it will have a different set of points.
MarkCan
« Reply #2 on: July 01, 2021, 00:06:01 »
Yes it is aluminum.
Thanks Dan
« Reply #3 on: July 10, 2021, 00:03:01 »
Quote
Yes it is aluminum.
Thanks Dan
Mark,
A 066 distributor? Are you sure?
Not a 062, 067  or a 0231 185 009 or 010 ?
I am not aware of a 066 distributor for the 280 SL ....
See here:
https://www.sl113.org/wiki/Electrical/Distributor
MarkCan
« Reply #4 on: July 10, 2021, 02:41:13 »
Mark,
« Reply #5 on: July 13, 2021, 20:45:50 »
Yes okay, Mark...
But was _that one_ really used on our cars (M130)...
It's not in our list...
dirkbalter
  • USA, CA, Corona
« Reply #6 on: July 14, 2021, 02:38:50 »
Not sure if it helps but my 108 had an 066 distributor originally.
Dirk
66 230 SL
70 280 SEL
53 CHEVY 3100
18 C300 COUPE
05 HD FLSTNI
MarkCan
« Reply #7 on: July 14, 2021, 13:19:55 »
Thank you all.
I’ll leave the points alone for the time being. At this moment current setup is performing quite well. In the future (once other bugs are ironed out) I would like to be able to install the Pertronix pickup.
