Author Topic: Manual transmission bearings  (Read 2932 times)
john collins
  • USA, VT, South Burlington
« on: June 22, 2021, 22:26:10 »
I am completely restoring my 1965 230sl and the manual transmission internals are all in very good shape, but since I am here, I thought I would replace the bearings.   It looks like they were replaced once before, as the identifying numbers on them appear “after-market”.  I can list those after market numbers, but I would prefer to find “correct” ones.
I do not have a parts manual to look up the actual part numbers - can anyone assist, so I can provide original part numbers to the Classic Center?
Here is a photo of the transmission, showing the tag….
Take care,
1965 230SL  white/black leather - power steering, Becker Mexico, kinderseat, fitted luggage
Re: Manual transmission bearings
« Reply #1 on: June 22, 2021, 22:47:05 »
I've used FAG bearings but I've also used others. I think any reputable bearing supplier could get you what you need for half the price of MB parts. Besides, MB doesn't make those parts, they just resell them.
john collins
« Reply #2 on: June 22, 2021, 22:56:37 »
These are the aftermarket bearings.
SKF 361727D (1)
NDH 3306 (1)
FAFNIR 305KDDC3 (2)
Take care,
wjsvb ✝︎
  • USA, VA, Virginia Beach
« Reply #3 on: June 23, 2021, 01:33:48 »
Agree with the good Doctor!  Name brand bearings (FAG, NDH etc.) are good: you can trace the part number to catalogs or mfr website and see construction specs if you want to confirm.
jon
67 250SL early
81 280SL Euro 4spd
« Reply #4 on: June 23, 2021, 03:18:12 »
The tag on the trans indicates that it is a replacement unit.
sandcrab59
  • USA, MA, Lunenburg
« Reply #5 on: June 23, 2021, 22:17:37 »
Cees is correct. All my manual transmissions, gas and diesels do not have tags.
Mine are all originals.
71 280SL-8  Euro
67 250 SL
72 220 D
1982 300 SD
1983 300SD
1985 300SD
1931 Model A Ford Roadster
1997 Corvette C5
« Reply #6 on: June 28, 2021, 10:14:15 »
Cees just gave you a big clue.  Your bearings were most likely changed by Mercedes when they rebuilt your gearbox.  I am sure the same bearings will be fine.
« Reply #7 on: June 28, 2021, 12:23:44 »
You can also bench test your old bearings. Clean them completely with solvent.
Lightly pinch them one at a time in the jaws of a bench vice (outside to outside). Rotate the inner race with your fingers. if any rough or flat spots are felt then the bearing is failing and should be replaced. In my case I automatically replace all bearings anyway since labor cost is most critical. Testing the old bearings however will confirm failing and noisy bearings when trying to diagnose problems with the unit.
