Author Topic: 67 230sl  (Read 3934 times)
Bconley759
67 230sl
« on: June 04, 2021, 22:02:03 »
So this fell out of the interior of my car when I flipped over bottoms up, I think it's part off one of the instruments, any ideas?
georgem
Re: 67 230sl
« Reply #1 on: June 04, 2021, 22:17:46 »
Can you give an idea of the size? A photo with something of known size often helps
George McDonald
Brisbane
230 Sl
1973 VW Kombi Single Cab Ute
Re: 67 230sl
« Reply #2 on: June 04, 2021, 22:54:24 »
Looks like the inside end from a broken tach or speedo cable.
georgem
Re: 67 230sl
« Reply #3 on: June 05, 2021, 00:58:17 »
following on from the Dr, is it like a spring with one end squared off - if so another accurate diagnosis from the Dr
George McDonald
Brisbane
230 Sl
Bconley759
Re: 67 230sl
« Reply #4 on: June 05, 2021, 11:19:10 »
It's 4 to 5 MM dia., I pretty sure it's probably Tac. cable, it is broken, there was some black electrical tape on one end. If you zoom in you'll see it has a squared off end and the rest is almost like a spring material.
Bconley759
Re: 67 230sl
« Reply #5 on: June 06, 2021, 15:55:52 »
I'm sure your probably correct, I need to get under the dash to take a closer look, Thanks.
