Author Topic: Gear stick slack  (Read 2207 times)
col320ce
Gear stick slack
« on: June 02, 2021, 21:14:54 »
This joint is where the gear lever attaches to and has the 2 nylon washers on each side. There is a fair amount of slack here even with new nylon washers. Is there a fix? I assume I just find a really thin nylon washer to take up the slack??  I don't think i want to over tighten the bolt...
Thanks for any help!
Col
1964 230SL
1965 250SE coupe
1993 320CE Sportline
Re: Gear stick slack
« Reply #1 on: June 02, 2021, 21:39:21 »
I squeeze the ends of the shifter tube a little in a vise until any play is reduced.
PeterPortugal
  • Portugal, Faro, Lagoa
« Reply #2 on: June 02, 2021, 21:55:56 »
I had to do the same.
1963 220se Cabrio
1968 280se Coupe
col320ce
« Reply #3 on: June 02, 2021, 22:17:14 »
Fantastic... Easy fix!!
Thanks again
Col
1964 230SL
1965 250SE coupe
