Author Topic: Help identify this connector  (Read 5528 times)
awk166
« on: May 08, 2021, 05:49:51 »
Hi I would be most grateful if someone could identify this connector and where it should be routed that goes from my foot dimmer/high beam switch on my 67 230.Thanks in advance!
WRe
Re: Help identify this connector
« Reply #1 on: May 08, 2021, 07:18:13 »
maybe this can help.
...WRe
awk166
« Reply #2 on: May 08, 2021, 13:16:55 »
Many thanks, that is really helpful!!
« Reply #3 on: May 08, 2021, 22:47:27 »
If it is an automatic, it might go back through the firewall then connect to the automatic transmission kick-down switch. ?
awk166
« Reply #4 on: May 08, 2021, 23:21:56 »
It's a 4sp manual, so I'm wondering if it's the connection for the reverse light switch on the gearbox. Thoughts??
« Reply #5 on: May 09, 2021, 02:00:19 »
Temporarily connect the two contacts of the plug together and turn on the ignition. If the reverse lights come on, you got it!
« Reply #6 on: May 09, 2021, 07:05:08 »
More likely to be the brake light switch.
lpeterssen
  • USA, FL, Miami
« Reply #7 on: May 09, 2021, 15:05:32 »
Yes it is the reverse light switch connector. Goes to the transmission reverse selenoid in the route market on the first post to this thread.  Check that cable Colours are grey/yellow one of them and the other as far as I remember was black/red/yellow.
lpeterssen
  • USA, FL, Miami
« Reply #8 on: May 09, 2021, 15:08:05 »
Dear mr. benz
Is not the brake light connector since it has a rubber grommet on it, and therefore is a signal for something outside the cabin, and as the car is a manual transmission, not automatic there is no doubt that is for the reverse lights switch
Best regards
L.peterssen
awk166
« Reply #9 on: May 09, 2021, 16:43:27 »
Many thanks for the answers, I will connect and check this tomorrow on the Pagoda.
Makes perfect sense as the 2 things not working right now are reversing lights and wipers. This looks to solve one of those issues.
« Reply #10 on: May 09, 2021, 19:25:59 »
Makes sense. Reverse light it is.
« Reply #11 on: May 13, 2021, 13:25:03 »
Awk,
What is your vin number for the 280SL?
Should be 113044 with either 10 or 12?
Which one is yours?
Your car is a manual so it should be a 10, automatics are 12.
Might be a leftover from a conversion from automatic to manual as this wire plug could be the kickdown switch.
I say this, because the rubber grommet is backwards, meaning the plug is outside the car, not inside.
Other way to verify is by checking the colors of the wires.
Walter
