Author Topic: Key stucked in door lock  (Read 2948 times)
Jowe
« on: April 25, 2021, 11:02:01 »
My key on drivers side stucked when I turned it for locking. Now I can't turn it back and remove it. I can't find any in the Manual or BBB about this. Any idea how to proceed?
Johan
badali
  • USA, Pa, Butler
  • 1966 230SL
Re: Key stucked in door lock
« Reply #1 on: April 25, 2021, 13:08:43 »
If you can push the button to open the door, you can remove the handle by taking out the bolt.  Then proceed from there.  The end of the lock on the inside may have hung up on something preventing you from turning the key.  Here are some posts to try.
https://www.sl113.org/forums/index.php?topic=19891.msg140510#msg140510
https://www.sl113.org/forums/index.php?topic=27380.msg199303#msg199303
https://www.sl113.org/forums/index.php?topic=17568.msg122618#msg122618
Brad
1961 220 Sb
1966 230 SL (Sold)
2019 E 450 4 Matic
2022 GLC 300 4 Matic
2025 E53 AMG Sedan
Jowe
« Reply #2 on: April 25, 2021, 14:12:38 »
Great, thank’s Brad. I will give it a try.
Johan
Norm
  • USA, TX, Wimberley
« Reply #3 on: April 25, 2021, 16:09:34 »
You probably tried this already but if not.....
Try relieving pressure on the key by using the inside lock switch.  Just "wiggle" the switch while doing the same with the key to see if it will release.
Norm
1966 230SL 162H Blue-Grey
1994 Acura NSX Formula Red
2024 Acura RDX A-Spec, White Pearl
2016 Mercedes S63 AMG Coupe Obsidian Black
2011 Harley Davidson Super Glide Light / Dark Root Beer
