Author Topic: Help requested identifying assorted small parts...  (Read 4671 times)
scoot
  • USA, CA, Altadena
« on: April 03, 2021, 16:41:40 »
Hi, here's one of my special parts bins.  There are some parts that I don't know what are.  Any comments/edits/ideas would be appreciated.
1.  Stainless steel wiper hold down nut
2.  Plastic finger nuts that hold down dash wood
3.  Horn pad retaining gizmos
4.  UNKNOWN thumb screws - what are these for?
5.  Misc. tail light retaining nuts
6.  Emergency bezels for early hazard switches
7.  Early chrome wiper caps that screw on - really heavy - what cars are these for?
8.  Long odometer/potentiometer knobs - what are these for?  W111 coupes?
9.  Unknown small thumbscrews. ?
10.  Vent levers for ? - badali says they are later heat levers for 111 sedan.
11.  Vent levers for ?
12.  Chrome vent levers - maybe for W111 coupes?- badali says they are early heat levers for 111 sedan.
13.  AC knobs - for which units?
14.  Part of rear view mirror.
15.  Misc switch knobs
16.  Small AC knobs - for which cars?
17.  Ivory seat back release/turn signal knobs
18.  Misc bezels
19.  Thumb screws for what?  Clocks on a W108?
« Last Edit: April 03, 2021, 17:22:11 by scoot »
Scott Allen
'67 250 SL (early)
Altadena, California
Vander
  • USA, OH, Columbus
Re: Help requested identifying assorted small parts...
« Reply #1 on: April 03, 2021, 16:53:16 »
Is #4 the thumb screws that hold down the carpet covered boards in the back seat area of a W113?
scoot
  • USA, CA, Altadena
« Reply #2 on: April 03, 2021, 17:08:33 »
Good guess, but my recollection is that those thumb screws aren't internally threaded all the way through to the top.  In other words, I think the part for the carpet cover is flat on top, not showing an internal thread.
Scott Allen
'67 250 SL (early)
GM
  • USA, CO, Boulder
« Reply #3 on: April 03, 2021, 17:10:06 »
On first look, I thought the #4 knobs were for that too, but the knobs/screws holding down the parcel shelves are male
Gary
1971 280SL - Sold
DB180 Silver Gray Metallic
Black MB Tex
scoot
  • USA, CA, Altadena
« Reply #4 on: April 03, 2021, 17:12:09 »
Good call.  I had forgotten that.  They are male.
Scott Allen
'67 250 SL (early)
badali
  • USA, Pa, Butler
  • 1966 230SL
« Reply #5 on: April 03, 2021, 17:16:05 »
12 is the early heat levers for 111 Sedans.  They are plastic in later models for impact protection.
10 is for later model 111 sedans.
Brad
1961 220 Sb
1966 230 SL (Sold)
2019 E 450 4 Matic
2022 GLC 300 4 Matic
2025 E53 AMG Sedan
« Reply #6 on: April 03, 2021, 19:01:46 »
#19 could be the knobs that clamp the bulb holder to the front of the central instrument cluster.
https://www.sl113.org/wiki/Electrical/Rheostat?action=download&upname=Rheostat_removal.jpg
GM
  • USA, CO, Boulder
« Reply #7 on: April 03, 2021, 20:11:11 »
Further to Alfred's note above, also for connecting the tach, speedo and clock to their rear mounting brackets?
Gary
1971 280SL - Sold
Black MB Tex
TOMNISTUFF
  • Canada, Qc, Levis
« Reply #8 on: April 03, 2021, 21:01:32 »
#1 are press-in grease fittings, 2 per door (1 per hinge).  Be careful mine were screw-in and instantly broke when I tried to remove them because they were plugged and wouldn't accept grease.  I had to drill them out and press in the ones you call #1.  By the way, if you order the original screw-in type by part number from Mercedes, you will still get the press-in version and have to rework your door hinges for them to work - don't bother to ask me how I know.
Tom Kizer
majercak
« Reply #9 on: April 05, 2021, 18:43:26 »
#16 - some of them look like Becker radio knobs - TR/slim face version
#18 - some look like Becker radio high/low switch, again TR/slim face version
« Reply #10 on: April 05, 2021, 22:06:20 »
12 is early 190SL levers. Probably used on sedans from the same era.
Desertpagoda
  • USA, AZ, Tucson
« Reply #11 on: May 09, 2021, 23:41:17 »
#8 you also used to see the longish odo knobs in a flexible material
kb
TJMart
  • USA, NC, Matthews
« Reply #12 on: May 11, 2021, 20:22:47 »
#13 look like the knobs for the under dash Frigiking Unit
Tony
1970 280SL, 4 Speed
TOMNISTUFF
  • Canada, Qc, Levis
« Reply #13 on: May 12, 2021, 11:57:46 »
In my earlier post, I misidentified the wiper shaft caps (#1) as grease fittings.  A closer look reveals that there is no hole or grease gun cone.  Sorry.
Tom Kizer
