Author Topic: Odometer Accuracy  (Read 3956 times)
thomas wright
Odometer Accuracy
« on: March 30, 2021, 09:10:16 »
Hi all,
My odometer appears to be recording less KM that I am travelling and I don't know why. The car was laying up for a number of years before I had it recommissioned with a new fuel tank and sender unit along with ancillary parts for brakes, exhaust system.
I had read on the forum that the correct tyres are needed as the circumstances of the tyre is important.  I measured my spare   unused tyre which is the same as on the car, Dunlop SP Elite 185R 14 90S Radial Tubeless.
Diameter:  25 1/2"  ( 645 mm)
Circumstances:  80  5/16"   (2040 mm)
Would you know if these tyre should record accurately the distances I travel or could you point me in the right direction for other cause of this problem.
Many thanks
280SL W113 1969 auto, 050 paint,  lhd.
WRe
Re: Odometer Accuracy
« Reply #1 on: March 30, 2021, 10:06:53 »
your tire size is correct, see att. file.
I would check it with a GPS system, e.g. mobile or navigation system. Otherwise your odometer needs some inspection.
...WRe
doitwright
  • USA, IL, Willowbrook
« Reply #2 on: March 30, 2021, 11:45:55 »
Unless you are the original owner, the speedo could possibly have been recalibrated to work with a different size tire. Just a possibility. It used to be and may still be true, before you sent your speedo in for service, they would ask you to count the revolutions of the speedo cable over a specified distance. There is a gear on the transmission that drives the speedo that could also be worn.
Frank Koronkiewicz
Willowbrook, Illinois
« Reply #3 on: March 30, 2021, 11:56:26 »
Is the difference vs. reality substantial? Do you also have similar differences with speed reading? Is it a couple of % points? Or more like between miles and kilometers?
Usually due to tires sizes you may be a couple of percentage points off as small differences in radius give small differences in wheel circumference.
thomas wright
« Reply #4 on: March 30, 2021, 14:12:45 »
Okay,
this is the full story.
After the car was commissioned and then new fuel tank fitted the odometer read 02494km on 3.4. 2020. I topped up with fuel on 4 occasions, last being 30.6.2020 to a total of 99.50lt ( 21.887 imperial gallons).
I used the car for short but regular journeys,  and through winter months until the fuel gauge showed it required a top up which I did on 21.2.2021. With the intention of establishing what my fuel consumption was I took an odometer reading,  it was 02661km which ment I had travelled a mear 167km  ( 103 miles) since 3.4.0202. It was at this point I thought 21gallons vs 103 mile equates to very high fuel consumption or the odometer reading is incorrect. That's the dilemma.
« Reply #5 on: March 30, 2021, 16:16:47 »
Check the odo with GPS, I would say, or vs. road poles before blaming it.
Then check the miles per gallon.
Then you may need to go through the linkage tour.
This is what i would do.
thomas wright
« Reply #6 on: March 31, 2021, 10:05:34 »
Thanks to all who helped ,you have given me a few options to follow and cure this problem.
cfm65@me.com
  • Cape Town, South Africa
« Reply #7 on: March 31, 2021, 17:27:15 »
Hi Thomas,
I live in a ‘metric’ country and my E Type has a mph speedo with a km face. The speed indication in kilos is very close to correct, but the distance travelled is in miles.
I guess this might be the case with you Pagoda.
Chris
Cape Town
28 Ford Model A Pickup
29 Chevy Phaeton
67 E Type FHC
67 250SL 5 speed
83 911SC
2015 VW T5 California Pop Top
thomas wright
« Reply #8 on: March 31, 2021, 18:08:25 »
Thanks Chris,
The thing is I am pretty sure my odometer dial is original as the car was ordered for the French market according to the Data Card, and I have owned it since 1976 and I believe I was the third owner as the car came out of the factory  on 29 July 1969. Nevertheless your point of view is worth considering as I investigate further.
« Reply #9 on: March 31, 2021, 19:15:43 »
FWIW, my speedo (which of course, is tied to the odometer) has consistently read between 3-7 MPH higher than actual. Actual checked with GPS speed app. I've been told that many cars do that: read a bit higher. My car has original sized tires, 185HR14.
MikeSimon
  • USA, OH, North Royalton
« Reply #10 on: April 09, 2021, 20:54:41 »
In Germany, there has always been a law that speedometers - and consequently odometers - are no allowed to read "low". This is to prevent arguments in court that your indicated speed was lower than what you were "clocked" for.
As a result, all vehicles produced in Germany over the decades have speed indication instruments that will show a higher than actual speed. I have a Porsche, a Mercedes 2 Audis and 4 German motorcycles and their speedos all show significantly "higher" than actual.
Some vehicles in Germany have to have officially "calibrated" speedometers/odometers (e.g.: Taxis) and the tolerance on calibrated instruments is around +5%, never under.
1970/71 280SL Automatic
Sandy Beige
Parchment Leather
Power Steering
Automatic
Hardtop
Heated Tinted Rear Window
German specs
3rd owner
