Author Topic: cranks but will not start  (Read 2647 times)
go2ml99
« on: March 14, 2021, 00:22:29 »
1969 280Sl will crank ,no smell of gas and will not turn over,any ideas thanks
Re: cranks but will not start
« Reply #1 on: March 14, 2021, 03:20:57 »
Check to see if  you can hear the electric fuel pump running. If not check the fuses. If you do not find a bad one twist the fuel pump fuse to re-new its contact, sometimes the ends corrode and loose contact.
« Reply #2 on: March 14, 2021, 11:59:59 »
I'm confused.
Cranks but doesn't turn over? They are the same thing. Do mean cranks but doesn't fire?
