Author Topic: Tachometer cable  (Read 2536 times)
Mohan58
  • Malaysia, Selangor, Petaling Jaya
Tachometer cable
« on: March 09, 2021, 15:06:36 »
Hi all,
Does anyone know if there is a difference in the tachometer cable between the manual & an automatic?
Is there is a difference between the RHD & LHD tachometer cable?
Is there a difference in the tachometer cable between the 3 SL models?
Thanks so much for your help.
Cheers
Cheers,
Mohan
W113 - 250SL
W126 - 280SE
W126 - 300SE
W212 - E250
Re: Tachometer cable
« Reply #1 on: March 09, 2021, 15:53:37 »
On LHD there is no difference between the automatic and manual on the tachometer cable. There is a difference in the speedometer cables.
« Reply #2 on: March 09, 2021, 16:50:27 »
Yes, there is a difference in tacho shaft between RHD and LHD - RHD is longer.
Mohan58
« Reply #3 on: March 10, 2021, 06:17:22 »
Thanks Joe.
Cheers,
Mohan
W113 - 250SL
W126 - 280SE
W126 - 300SE
W212 - E250
Mohan58
« Reply #4 on: March 10, 2021, 06:19:01 »
Thanks Pawel. So other then the length difference, there is no other differences? Are the heads of the cable at each end the same as the LHD?
Cheers
Cheers,
Mohan
W113 - 250SL
W126 - 280SE
W126 - 300SE
W212 - E250
« Reply #5 on: March 10, 2021, 06:30:05 »
Mohan,
Other the the cables being longer for the RHD cars, remember that the input point on the speedo is off set to the opposite of a LHD unit.
