Author Topic: Two new issues  (Read 2496 times)
john.mancini
  • USA, FL, Nokomis
Two new issues
« on: March 01, 2021, 18:47:54 »
My 1969 280SL, with only 45,000 original miles, has developed two new problems. 1. Difficult hot starts. When the engine is cold it starts right up and runs like a top. Once the engine is hot, if I shut the engine off, it's difficult to start it back up. 2. Automatic transmission does not seem to hold in Park. It slips out of gear. Any suggestions or solutions on either problem would be welcomed.
John
65 230SL 519 Red 4-sp
98 911 cab
56 Ford F100
08 Porsche RS60 Spyder
23 Z4M40i
Re: Two new issues
« Reply #1 on: March 02, 2021, 05:51:37 »
Most likely the shifter rod bushings are falling apart causing the parking lock problem. With a low mileage car like yours, I would check the electrical fuses since a corroded fuse could disable your starting aids. Otherwise a starting aid relay, most likely needs it's electrical contacts cleaned. Check
and "twist" each fuse first to rule a fuse problem out.
john.mancini
  • USA, FL, Nokomis
Re: Two new issues
« Reply #2 on: March 06, 2021, 14:53:33 »
Thank you Joe. I replaced the shifter bushings but the problem, although not as bad, still exists. The car seems to shift out of park, or for example, into 4th to 3rd, on its own.
John
98 911 cab
56 Ford F100
23 Z4M40i
