Author Topic: Correct Coil - 1971 280SL  (Read 3076 times)
Benz280
  • USA, NJ, Jersey City
« on: February 25, 2021, 23:30:05 »
Looking to replace original coil ( Blue ) ( works fine , but looks tired ) with Bosch #0221122001.
Current ceramic ballast is Blue. Should this be changed ?
1971 280SL 4 Speed
1995 E320 Cab
1965 Shelby GT350
Re: Correct Coil - 1971 280SL
« Reply #1 on: February 25, 2021, 23:38:13 »
This is for transistorized ignition. I have the red one in 1970 280SL, but maybe you have transistorized ignition...
Some info here: https://www.sl113.org/wiki/Electrical/IgnitionCoil
« Reply #2 on: February 27, 2021, 13:17:10 »
If the transistorized ignition is still hooked up you should have 2 resistors. One on the bracket for the hood prop and one down near the coil.  If memory serves the upper one on the bracket is blue and the lower is silver.  Also look where the green wire from the distributor goes.  If it goes under the battery that is the right coil.  If it goes to the coil that means the transistorized ignition has been removed and that is the wrong coil.  For what it is worth it is pretty easy to restore the blue coil.  Copies of the logos are a available on this site in the technical manual. You can print them on sticker vinyl and the paint is available in cans from Rustoleum. The color escapes me but I can post it here if you want.  It would be a good little restoration project.  Remove it, sand it, paint the blue, clean up the top, light coat of clear over the whole thing and 2 new nuts and washers Regardless, save the old one.  So many transistor ignition cars have had the system removed that the parts were some of the hardest to find in my entire restoration.
Benz280
« Reply #3 on: February 27, 2021, 14:46:50 »
Thank you both for your 113 Ignition Coil insight .
It will be curious to see if the new coil has any better performance .
1971 280SL 4 Speed
1995 E320 Cab
1965 Shelby GT350
